Pietenpol-List: corvair engine gripe
Posted: Thu Jan 15, 2004 9:53 am
Original Posted By: "DJ Vegh"
Last night, I was trying to clean up the garage a bit and the plan was toremove all the cooling tin from the Corvair engines I just got so they wouldneatly fit into the corner. Just to pull the tins off, I used every wrenchfrom 1/4" to 5/8", it was nuts! I've pulled whole engines apart with lesswrenches.Anyway, I was going to snap a picture of the cute little buggers lined up inthe corner and attach it, but that may be just silly. Also, the questionperiodically arises about where a person should start an airplane project.The following is a section taken from an email that I sent to anothergentleman, here are my thoughts:My opinion is that you should start with the engine first. Some people saythe tail feathers or the wing ribs, and it's too easy to quit after justbuilding those. I think it would be hard to futz around for a few yearsbuilding inexpensive parts, and then try to justify the most expensivecomponent on the aircraft. If you are willing to build the engine first,build a test stand, strap on a prop, and run the damn thing, just thepresence of that assembly in the shop would provide the pressure tocontinue. Additionally, the engine complete won't consume anywhere near thefloorspace as it sits and waits for the completion of the rest of theproject, unlike a set of wings or a fuselage.Robert HainesDu Quoin, Illinois________________________________________________________________________________
