Pietenpol-List: Wing tank side reading gauage
Posted: Wed Feb 25, 2004 10:01 am
Original Posted By: Leo Gates
Subject: Pietenpol-List: Wing tank side reading gauagePieters:I have been visiting with Rochester Gauges here in Dallas about turning the cylinder inside their spiral action fuel gauge upside down so it will registerfuel quantity correctly in a center section wing tank application. This is a precision magnetic gauge with a float traveling on a spiral rod to record fuel level on hermetically sealed side-reading dial marked E,1/4,1/2,3/4,F. All aluminum construction. Housing has 1-1/2" NPT male threadsfor connection to threaded bushing (they sell aluminum bushings and flanges for thisgauge as well). Length "L" 6", Float Travel 4-1/4". In the 1999 AS&S catalogue they sold a top mounted one for $39.00.They manufacture them here in Dallas. If I can talk them into making one that will mount on the bottom of a tank, instead of only from the top, how manyof you would be interested in purchasing one. They have a $125.00 minimum order for PO's. I have a tax I.D. # and could purchase them direct, if enoughof you are interested. They are supposed to call me back and let me know if theycan or will make this gauge as per my request. I thought it might have a greater influence on them if they could sell more than one. We have not got aprice yet, or if they will do it, but, I don't expect it would be a lot higherthan the 1999 AS&S price on the similarly built top mount fuel gauge.If any of you are interested let me know back ASAP. Bargaining power will be much better with numbers, I'm sure.Thanks,MaxArlington, TX.________________________________________________________________________________Date: Wed, 25 Feb 2004 10:28:26 -0600
