RE: Pietenpol-List: Axle
Posted: Fri Feb 27, 2004 6:02 pm
Dave,I am using 1 1/4 x 0.120 4130. I bought the ready made axle from Aircraftspruce. Looks about the right size too.CheersPeter.-----Original Message-----
Posted: Fri Feb 27, 2004 7:30 pm
Dear List, I ordered my axle (for a wood gear - spoke wheel set up). I ordered 1 1/8X .083 Chromoly Tubing from Wag-Aero. Never having ordered Chromoly Tubing beforeI wasn't sure what to expect. It has arrived and it looks and feels justtoo light and flimsy to serve as an axle. So, did I screw up, or is this thesame material that most builders are using? Dave________________________________________________________________________________
Posted: Fri Feb 27, 2004 8:28 pm
Original Posted By: "Shawn Wolk"
Dave,The Flying and glider plans call out 1 1/4 X 12 GA. Chrome-Molybdenum for theaxle. 12 GA. is .1045" thick, I think most guys go up to .120" rather than downto .095".1 1/8 X .083" does sound a little light and flimsy.Mine is split axle and I chose 1 1/4 X .120".Skip I ordered my axle (for a wood gear - spoke wheel set up). I ordered 1 1/8X .083 Chromoly Tubing from Wag-Aero. Never having ordered Chromoly Tubing beforeI wasn't sure what to expect. It has arrived and it looks and feels justtoo light and flimsy to serve as an axle. So, did I screw up, or is this thesame material that most builders are using? Dave________________________________________________________________________________
Re: Pietenpol-List: Axle
Posted: Fri Feb 27, 2004 9:07 pm
Original Posted By: dpaul
I used 1 1/8" x .100 and was not happy with the amount of bow in the axle. I switchedit to a 1 1/4" x .120Dick N. ----- Original Message -----
Posted: Sat Feb 28, 2004 6:10 am
Original Posted By: Carbarvo(at)aol.com
Clif, Your right. F&g 1 1/2 X 12 GA. The 1934 plans split axle 1 1/2 X 10 GA. (.130")My landing gear is a combination of 1934 plans, Grega, and Wag Aero Sport trainer,because I wanted wider tread than Piets 56". Wag Aero has the 1 1/4 X .120".Skip, reading better with morning light and stronger glasses.All the plans I've got specify 1 1/2" tubing.That's the 1932 Fly+Glide Piet, 1933 F+GScout split axle and my plans from DonPietenpol.Where's this reference to 1 1/4"? My copiescame from EAA 10 years ago. Did theymake a change somewhere along the line?Clif________________________________________________________________________________
Posted: Sat Feb 28, 2004 12:38 pm
Nice looking work Clif. I especially like your airspeed emblem.Weav ----- Original Message -----
Posted: Tue Jun 17, 2008 6:17 am
Posted: Tue Jun 17, 2008 6:23 am
.120 is the correct size if you're going brakeless. The axle length will be extended if you install brakes which may require upsizing or heat treating for added strength.Greg C. ----- Original Message -----
Posted: Tue Jun 17, 2008 3:49 pm
Mine are the same as Jack's.Dick N. ----- Original Message -----
