Pietenpol-List: Magnetic gauge
Posted: Fri Feb 27, 2004 9:33 pm
Original Posted By: Barry Davis
The key word in Max's post is that these are "magnetic". I beleive the Rochester gauge uses a magnet at the end of the spiral rod. Thepoles of this magnet align with another magnet that is attached to the indicatingcard. The magnet on the spiral is in the gas. Then there is the aluminumof the housing and then the card is "outside" of this housing in the air, balancedon a point as is a compass. There is no way for fuel to leak out ever!Hence, the "hermetically sealed" statement. The magnetic field carries throughthe aluminum of the housing to enable this. Once the poles of the two magnetsalign, they don't move out of alignment at all. It remains rigid in the magneticflux.This is the way the fuel gauges in the P-51 Mustang and the PT-19/22/26 worked.Look at one if you ever get the chance. Max, confirm this is the way they are constructed. I am quite sure from the descriptionthat this is the case. If it is indeed true then it is the way to go.These would be the most superior of the float style gauges to use!chris bobka ----- Original Message -----
