Pietenpol-List: The myths about rib stitching
Posted: Thu Mar 18, 2004 8:25 am
Dave,The outside vee fitting in the lower right corner of the of figure 6A ispretty clear, 16 gage steel. The other inside vee, outside and insidelanding gear fittings are not very readable, but do look like 16 gage, mostlikely, probably ;Dave,The outside vee fitting in the lower right corner of the of figure 6A is pretty clear, 16 gage steel. The other inside vee, outside and inside landing gear fittings are not very readable, but do look like 16 gage, most likely, probably;)Maybesomeone who actually made this type of gear will write in and say what thickness4130 they used.Skip My Flying and Glider Manuel is a little blurred. It appears that the steel that is used to reinforce the areas around the wood landing gear on page 17 is 16 gage steel. Even with a magnifying glass it is hard to be sure. Can someone confirm that it is 16 gage. Thanks. Dave in Missouri________________________________________________________________________________Subject: Pietenpol-List: The myths about rib stitchingDate: Thu, 18 Mar 2004 06:27:28 -0800
