Pietenpol-List: Rib layout question
Posted: Mon Apr 19, 2004 9:04 am
Original Posted By: "Dan Loegering"
Subject: Pietenpol-List: Horizontal stab questionJust to make sure before I start glueing, does the 3/16" ply that goes on the leading edge and center beam go on top and on the bottom of the stabilizer?Thanks________________________________________________________________________________Subject: Pietenpol-List: Rib layout questionDate: Mon, 19 Apr 2004 10:15:00 -0500
Re: Pietenpol-List: Horizontal stab question
Posted: Mon Apr 19, 2004 10:28 am
Subject: Re: Pietenpol-List: Horizontal stab question I'm not sure if I read your problem right? But youdo put the plywood gussets on top, but if you use PolyFiber like I did, you have to cut strips of wood to goaround the stabilizer to fill in the gaps betweenplywood gussets, as Poly Fiber dacron heat shrinkcovering, needs a constant perimeter level piece ofwood to glue to, so when you shrink it, it shrinksevenly. If you have a gap on the perimeter yourdacron will sag in the gap without a surface to glueto and shrink distorted. I learned the hard way!Ray --- At7000ft(at)aol.com wrote: > Just to make surebefore I start glueing, does the> 3/16" ply that goes on the > leading edge and center beam go on top and on the> bottom of the stabilizer?> > Thanks> your friends today! Download Messenger Now http://uk.messenger.yahoo.com/download/ ... __________
