Pietenpol-List: Pietenpol Information List
Posted: Tue May 11, 2004 9:41 pm
Subject: Pietenpol-List: Pietenpol Information ListI've put together an 'Information list' for the benefit of builders, as well as flyers to refer to. I'm e-mailing it out to everyone I have e-mail infomation on. I've got about 66 'Infomation Lists' filled out so far, and ifyou like, I'll add your project to the list. Please take the time to fill it out,and get it back to me, and I'll present the results at Brodhead this year. Feel free to add any notes, or anything. If you 'click, drag and highlight' thelist below, then click 'reply', it should be on my return e-mail, and you can just fill in each line, then e-mail it back to me. Thank you, and Happy Flying !!Chuck GantzerWichita, KSNX770CGN Number -Name - Aircraft Information :Type -Total Time - hrs.Short / Long fuse -Empty Weight - lbs.Gross Weight - lbs.Engine -Prop - XEmpty CG aft of Lead Edge - "Weight of Primary Pilot - lbs.Max Pax Weight - lbsInches wing tilted back - "Cabane strut length - "Cowling Material -Covering -Paint Process -Wheels -Tires -Brakes -Brake Pedals -Tailwheel -Bunji Chord / Springs -Seat Belt Harness -Survival Tools -Adhesives used: Ribs - Wing - Fuse -Fuel Capacity: Range - hrs. Wing Tank - gal. Material - Cowl Tank - gal. Material -Alterations : Fuselage Width - " Wingspan - ' " Engine Mount Length - " Fuselage Front Extension - Landing Gear Position - " Other -Wood type in various locations: Ribs - Rib Gussets - Spar Size - X Spar Material - Longerons - Longeron Gussets - Other -Steel type in various locations: Cabane Struts - Lift Struts - Landing Gear - Engine Mount Fittings - Fuselage Fittings - Firewall - Other -Airspeeds: Vr (rotation) - Vx (best angle) - Vy (best rate) - Vne (never exceed) - Vs1 (stall) -Build Time - Date first airplane noises / /Date Airworthyness Certificate / /Date of the first flight / /Address -e-mail - web site -builder(s) -________________________________________________________________________________
