Pietenpol-List: How about some help from one of you "engineer" types?
Posted: Tue Jun 01, 2004 5:53 pm
I need to mount a step somewhere near the front of my fuse so I can get up to thecenter section tank in case (well, ok, WHEN) there's not a ladder handy.....So I'm thinking about mounting a length of round 5/8"-.095Wall Thickness (WT) 4130tubing inside a piece of 3/4"-.058WT tubing so that it can telescope out around6" or so......and that will be my step.....I have no idea even what range of sizes to plan for without doing some tests, aVERY expensive process when using 4130......Any estimates on what kind of load this setup would handle? Or what other combinationsmight come close to handling 200lbs plus a fuel can (maybe an additional40lbs)?jm________________________________________________________________________________
