Pietenpol-List: Aghh, so close... and thanks
Posted: Fri Jun 11, 2004 1:25 pm
Original Posted By: Waytogopiet(at)aol.com
Subject: Pietenpol-List: Aghh, so close... and thanksThank you to all!! Clif, my 12/1 slope will be done in the 3/4 thickness of spar(I will splice it in the modern way, not like Bernard did). That will costme about 3" to 4" on each spar, just the triangle between the last rib and wingtip. It coul be less (about 2,5") if I go for a 10/1 slope. I will put gussetsin the joint anyway. Wing tip, as I understand, are also compression members,could that be a problem? Thanks again.Santiago---------------------------------Cmo uss el correo electrnico?Qu penss del spam y de los virus?Clic aqu________________________________________________________________________________
