Pietenpol-List: Gussets and plywood question
Posted: Sat Jun 19, 2004 11:07 pm
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 15 Msgs - 06/18/04Hey, Fellas! (and gals, too, if any), I have read everything I have about wood, and except for one comment that hardwoods are mainly used in block form, I can find nothing about the selection and use of hardwood. I am particularly wondering about the two piecesof white ash in the fuselage, between the landing gear fittings. The plans specify 3/4 X 2" cross members at the floor level. How do you select the wood for these pieces...quarter sawn, vertical grain, yadda, yadda, yadda or what? Could you substitute oak? I'd eally appreciate the help of anyone who has dealt with this problem. Thanks in advance. Don Cooley Fairfield, CAP.S. Wish I could join you at Brodhead, maybe next year! DC ________________________________________________________________________________Date: Sun, 20 Jun 2004 02:08:48 -0300 (ART)Subject: Pietenpol-List: Gussets and plywood questionHello. As I previously said, Im from Argentina. Here is almost impossible to get1/16 plywood, my choices are buy it from Aircraft Spruce, Wicks, etc.(reallyexpensive), custom made plywood (we do have birch sheets, about 0,6mm or .0236inches) or use 1/8 cedar marine plywood (very cheap, 17 dollars for a 7' x5,25 sheet) for the ribs gussets. I know that 1/8 has been previously used but,would this add to much weight? What do you think? Another question. Im ableto buy 1/4 cedar plywood for the fuselage floor, but this is just 3 ply. Couldthat work anyway? Thanks.Santiago Morete---------------------------------Internet gratis y que funciona!Tres nuevas ciudades con nmeros locales:Escobar, Zrate, CampanaQu espers para navegar bien y rpido?________________________________________________________________________________
Re: Pietenpol-List: Gussets and plywood question
Posted: Sun Jun 20, 2004 6:05 am
1/8 plywood for the rib gussets will not add any appreciable weight. Beware ofany changes this may require of the metal fittings for the drag/anti-drag fittings.If the 1/4 cedar plywood you have is also marine grade plywood it will work justfine.Greg Cardinal in Minneapolis ----- Original Message -----
Posted: Sun Jun 20, 2004 8:15 am
Santiago,You may want to investigate using fiber/cardboard. You'd have to research it,but my 83 yearold AP mentor tells me that many of the old certifiied aricraftused like a fiber (actually paper I think) board, as gusset material.walt evansNX140DL ----- Original Message -----
Posted: Sun Jun 20, 2004 9:01 am
Why can't we ship it to you? Maybe cut a sheet up into 2" or 4" strips or 8 1/2X 11" pieces and mail them? Or even 11" X 17"....both "standard" envelope sizes....I know that's not optimum and there will be some waste, but a bit ofplanning could eliminate a lot of that waste.....I know that doesn't help with the leading edge covering maybe this approach wouldwork?Let me know if that works for you and I'll go get some, cut it into strips (orsomething like 8X10" pieces) and mail it.....I would think that your total costwould be MUCH less than the Aircraft Spruce/Wicks route.....Am I missing something? Seems like a good approach.....Jim in Plano..... ----- Original Message -----
Posted: Sun Jun 20, 2004 12:36 pm
Aeronca used cardboard gussets and years ago if you wanted to fly a set of thesewings you had to replace them with plywoodas they disintegrated over time.Al Latham ----- Original Message -----
Posted: Sun Jun 20, 2004 4:14 pm
Subject: Re: Pietenpol-List: Gussets and plywood questionHi Jim...My 2 cents...I understand that on the early Piets, Bernie used old campaign posters to cover the leading edge. Anybody got anything on this?________________________________________________________________________________
Posted: Sun Jun 20, 2004 4:21 pm
Original Posted By: Carbarvo(at)aol.com
It was actually oatmeal boxes...... ----- Original Message -----
Posted: Sun Jun 20, 2004 5:00 pm
Original Posted By: Robert Doebler
Subject: Pietenpol-List: Gussets and plywood questionOk. Thanks Jim!!! That sounds very interesting. I dont want abuse of your generosity,but, if you can send me these little pieces, I will appreciate it verymuch. If you agree, I will contact you at your e-mail address. I am not reallyworried about the leading edge plywood cover. Probably I will use aluminum orjust install false ribs (like in that beautiful yellow piet). Thanks again.Santiago---------------------------------Internet gratis y que funciona!Tres nuevas ciudades con nmeros locales:Escobar, Zrate, CampanaQu espers para navegar bien y rpido?________________________________________________________________________________Date: Mon, 21 Jun 2004 12:41:15 -0700 (PDT)
Posted: Tue Jun 22, 2004 6:38 pm
For what it's worth -- a 1/2 sheet of 1/16 birch is about 4 lbs -- cut upinto 12" squares, it's a package 1" thick -- It will ship to Argentina inabout 10 days for $26 via "Airmail Letter Post".Mike (who once shipped a bicycle wheel to Slovenia!)Pretty Prairie, KS ----- Original Message -----
Posted: Tue Jun 22, 2004 6:43 pm
Re: Pietenpol-List: One piece landing gear reinforcement straps and brackets
Posted: Tue Jun 22, 2004 7:23 pm
Hi:Yes, it has been done before.Thats what I did; routed out a groove in the bottom of the ash cross piecesand installed the assemblies before I put the luan plywood floor piece inplace. This reminds me of another method re the floor. I temporarilyattached the ply with screws and fitted in place; the marked out thelocations of the rudder bar post and the front rudder pedals and installedthem on the ply before putting it in permanently.One mistake I made was making the LG brackets per Bernies dimensions;should have made the lift strut lugs longer.Just another way of getting there.See ya'll in Brodhead.Lou Larsen----- Original Message -----
Posted: Tue Jun 22, 2004 7:53 pm
Original Posted By: "Laurits Larsen"
Read and head! Almost ALL of the lugs andtabs should be made a little longer.You will save yourself a lot of grief.Greg Cardinal----- Original Message -----
Posted: Tue Jun 22, 2004 9:09 pm
That should say "Read and HEED".......----- Original Message -----
Pietenpol-List: Shirts for sale
Posted: Tue Jun 22, 2004 9:10 pm
Guys,Bill Weeden still has some nice shirts for sale. A sample picture of the backof one of the shirt types is below. 15 bucks each and he has already "lost hisshirt" on these. I just got five.ChrisChris,OK, here's what I have left. There will probably never be any moreafter these are gone.All are adult sizes.SMALL - 1MEDIUM - 10LARGE - 13I'll send you as many as you want. $15 each. I can ship one shirtPriority Mail for $3.85. Two shirts comes to just under $5 to ship.I don't think I've shipped more than two at a time. However many youwant, I will box them up and have it weighed. Just let me know.Thanks,Billp.s. I also have four of the SCOUT shirts left, all are size LARGE.Printed in three colors on the front only. They are $12 each.billrobin(at)wekz.net________________________________________________________________________________
