Pietenpol-List: The Annual Inspection - Powerplant; a new video
Posted: Mon Jun 28, 2004 9:01 am
Original Posted By: KTS5TA6(at)wmconnect.com
I don't normally spam on this list, but I've been working on this video forabout a year, its my first one, and I'm kinda proud of it. So here goes:THE ANNUAL INSPECTION - POWERPLANT 55 minutes Follow Westwood College of Aviation A&P instructors Tim Guerrera andVaughn Dowell through a step by step demonstration of an annual inspectionof typical Lycoming 0-360 powerplant section. This video explains everystep of the process from an initial AD search to the final log entries.Each procedure is detailed including compression check, ignition timing,spark plug service, exhaust pressure check, oil change, fuel system,propeller, electrical system, etc..... , showing the proper techniquesalong with plenty of professional hints and tips. A final segment detailssafety wiring techniques as used throughout the powerplant section. Most of this video was filmed at Westwood College in Denver using aPiper Archer, however a few segments were done locally in Granby, CO with myRV-6A and hangarmate Dave Cook's RV-6.available now in DVD and VHSfrom Builder's Bookstorehttp://www.buildersbooks.com/annual_inspection ... ant.htm800 780-4115...and to sweeten up the spam, mention "Matronics" when you order and get25% off through the end of June.Thanks,AndyRV-6A N-5060 flying________________________________________________________________________________
