Pietenpol-List: Forward CG limit
Posted: Fri Aug 06, 2004 9:20 pm
I know the aft most CG location is 20" aft of the wing LE. That info is on theplans. What about the recommended maximum forward CG location? I don't see iton the plans and can't recall any discussions about it.I'm getting all of the paperwork together for the final inspection and this bitof info is needed.Thanks,Greg CardinalMinneapolis________________________________________________________________________________
Re: Pietenpol-List: Forward CG limit
Posted: Fri Aug 06, 2004 10:26 pm
Original Posted By: gcardinal(at)mn.rr.com
Hi GregOn both of your questions;15 inches is the most forward CGFor my inspection I put mine on the panel of the forward cockpit, citing the ruleon antique models. That didnt get by with the inspector. I had to mount asecond one on the left side under the horiz stab.Would you like a copy of the Piet operations manual? The inspector seemed to likeit. I posted it to the Matronics pic file.Dick N. ----- Original Message -----
RE: Pietenpol-List: Forward CG limit
Posted: Fri Aug 06, 2004 10:28 pm
Hi Greg (Slightly off-topic)Did you see the writeup in Kitplanes magazine about your panel? I think thephotos came out great! Your panel sure is a beauty.best, Cory -----Original Message-----
Posted: Fri Aug 06, 2004 10:30 pm
Subject: Re: Pietenpol-List: Forward CG limitRecommended Piet CG range is 25% to 33% chordor in other words....15 in. to 20 in. aft of the wing L.E.TLB________________________________________________________________________________
Posted: Fri Aug 06, 2004 10:32 pm
Original Posted By: "Cory Emberson"
Subject: Re: Pietenpol-List: Forward CG limitWhat issue of Kitplanes??? I'll need to look for that!________________________________________________________________________________
Posted: Fri Aug 06, 2004 10:35 pm
It's the June issue, which is a few issues old. It's the Builder's Reportthat's bannered across the top of the cover.It's a *beautiful* panel! -----Original Message-----
Posted: Fri Aug 06, 2004 10:40 pm
Original Posted By: Richard Navratil
Dick,I thought the instrument panel location for the data plate would not fly with Mr.Norris.What did your plate by the tail say on it? What is it attached to? What is itmade of?Chris ----- Original Message -----
Posted: Sat Aug 07, 2004 7:29 am
Original Posted By: Cory Emberson
It was actually in the July issue. Thank you, Cory, for writing that up. Dale andI have received lots of good feedback from that.Greg ----- Original Message -----
Posted: Sat Aug 07, 2004 9:54 am
Oh, you're right - July was interiors and exteriors. I saw "Panels" andthought "Greg's Piet." Glad you and Dale received good reviews! :-)best, Cory -----Original Message-----
Posted: Sat Aug 07, 2004 4:02 pm
It is Stainless steel and has to have the serial #,Name of Builder,and Model.Under the horiz stab there is an area where there is a ply gusset that re enforcesthe tail post. I screwed it into that.Dick ----- Original Message -----
