Pietenpol-List: gascolator location
Posted: Thu Aug 26, 2004 11:41 pm
Original Posted By: "Hayes, Mike"
it's pretty tight down by the bottom end of my firewall. I'm trying to getthe gascolator as low as possible...... I know that typically you aresupposed to put it as low as possible without it protruding from beneath thefirewall.The optimum location for mine puts the bottom edge of the gascolator about1" below the firewall. How strict is the rule of keeping it above thebottom firewall line? I could move it higher but not by much.I knwo the reasoning is that if the landing gear ripped out it could alsorip off the gascolator... BUT If the landing gear was to be ripped off itwould most likely happen in a loss of power forced landing in which case thefuel tank shut off valve would be put into the closed position before theattempted landing anyway.Some opinions here please.... keep it a tad low or make a miracle happenand find a way to raise it????DJ V.N74DVMesa, AZwww.imagedv.com/aircamper________________________________________________________________________________
