Re: Pietenpol-List: Need Help on Horizontal Stab - AN43 eyebolt hinges
Posted: Sun Aug 29, 2004 4:39 pm
be very creful with the AN43 eyebolt style hinges. If you do not secure them sothat they can not rotate in the hole you could get a locked up control surfacein flight.A good way to keep them from rotating is to use the drilled shank version witha castle nut. instead of putting a cotter pin on it, use a short length of musicwire that has a round loop bent into one end. Slide it through the shankand use a wood screw through the loop and screw it into lead or trailing edgespar. It is only necessary to secure one side of the hinge.DJ ----- Original Message -----
