Pietenpol-List: Aileron rib build questions
Posted: Wed Oct 06, 2004 10:13 am
Original Posted By: "Textor, Jack"
Subject: Re: Pietenpol-List: N74DV's first passengerDJ,Excellent story !! Ya gotta include that one in your Test Flight Log.Chuck G.________________________________________________________________________________Subject: Pietenpol-List: Aileron rib build questionsDate: Wed, 6 Oct 2004 11:03:07 -0500
RE: Pietenpol-List: Aileron rib build questions
Posted: Wed Oct 06, 2004 12:21 pm
Re: Pietenpol-List: Aileron rib build questions
Posted: Wed Oct 06, 2004 7:26 pm
I completely agree with Steve E. I also used alominum piano hinge. Do it allbefore cutting.Dick N. ----- Original Message -----
Posted: Wed Oct 06, 2004 8:35 pm
Subject: Re: Pietenpol-List: Aileron rib build questionsLike Steve E. & Dick N. said, build the entire wing and aileron as an assembly, including pre fitting and drilling the holes for the aileron hinges.The wing should be complete, before you cut the ailerons loose. I used the plans type barn door hinges, but replaced the aluminum hinge pin, with AN hardware. The AN hardware I used was a screw with a long enough shank to go all the way through the hinge, cut the threads off, and drill a small hole for a cotter pin. Use a small flat washer under the cotter pin. I bridged the aileron gapwith 3" fabric, before any paint was applied.Chuck G.________________________________________________________________________________
