Pietenpol-List: "engine turning" cowlings
Posted: Wed Oct 13, 2004 7:33 am
Gentlemen,I'm not sure what the proper term is, but I'd appreciate thoughts on how to getthose "turning/swirl" marks on a bare aluminum cowling.Is it a very fine stainless wire brush in a die grinder or one of those nylon abrasivebrushes?? With a piece of metal the size of the cowling parts, using a drill press is out,so I assume it'll have to be handheld, maybe with some sort of jig.Thoughts??Douwedouweblumberg(at)earthlink.net________________________________________________________________________________
Re: Pietenpol-List: "engine turning" cowlings
Posted: Wed Oct 13, 2004 7:47 am
Original Posted By:> "Douwe Blumberg"
HI Douwe,It is called "Engine Turning". I did my instrument panels using an old intakevalve with a circular pad of Scotchbrite superglued to it, mounted in my drillpress. It only takes a second of pressure to put the swirls into aluminum.Jack Phillips>
Posted: Wed Oct 13, 2004 5:51 pm
Original Posted By: "Carl D. Vought"
Posted: Fri Apr 28, 2017 9:30 pm
> To: "pietenpolgroup" > Subject: Pietenpol-List: "engine turning" cowlings> > Gentlemen,> > I'm not sure what the proper term is, but I'd appreciate thoughts on how to getthose "turning/swirl" marks on a bare aluminum cowling.> > Is it a very fine stainless wire brush in a die grinder or one of those nylonabrasive brushes?? > > With a piece of metal the size of the cowling parts, using a drill press is out,so I assume it'll have to be handheld, maybe with some sort of jig.> > Thoughts??> > Douwe> douweblumberg(at)earthlink.net> > > > > > > > > > > > > ________________________________________________________________________________Date: Wed, 13 Oct 2004 09:26:12 -0400
> > To: "pietenpolgroup"> > > Subject: Pietenpol-List: "engine turning" cowlings> > > > Gentlemen,> > > > I'm not sure what the proper term is, but I'd> appreciate thoughts on how to get those> "turning/swirl" marks on a bare aluminum cowling.> > > > Is it a very fine stainless wire brush in a die> grinder or one of those nylon abrasive brushes?? > > > > With a piece of metal the size of the cowling> parts, using a drill press is out, so I assume it'll> have to be handheld, maybe with some sort of jig.> > > > Thoughts??> > > > Douwe> > douweblumberg(at)earthlink.net> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >> Contributions> any other> Forums.>> http://www.matronics.com/chat>> http://www.matronics.com/subscription> http://www.matronics.com/FAQ/Pietenpol-List.htm> http://www.matronics.com/archives> http://www.matronics.com/photoshare> http://www.matronics.com/emaillists>> > > > > ________________________________________________________________________________Date: Wed, 13 Oct 2004 14:41:36 -0400
