Pietenpol-List: Fuselage sides
Posted: Sun Oct 17, 2004 9:29 am
Subject: Pietenpol-List: Fuselage sidesIs it okay to splice the fuselage side plywood at an upright? I purchased some 4x4' pieces of ply from McCormicks -- they didn't have any 4x8' sheets. Ifit's not a good idea that's okay as I'll use the 4x4' pieces for gussets, etc.Just wondering...Fred B. La Crosse, WI________________________________________________________________________________Date: Sun, 17 Oct 2004 10:43:16 -0400
Re: Pietenpol-List: Fuselage sides
Posted: Sun Oct 17, 2004 9:53 am
Original Posted By: TBYH(at)aol.com
If it is a scarf joint 12 to 1 See AC 43.113-1b for details.Cy Galley - Chair,AirVenture Emergency Aircraft RepairA Service Project of Chapter 75EAA Safety Programs Editor - TCEAA Sport Pilot ----- Original Message -----
Posted: Sun Oct 17, 2004 1:59 pm
I did. I butted mine together on top of a diagonal or upright. Glued a correspondingstrip of 1 1/2 inch plywood over the butt joint and seems to work ok.If it's under the fabric nobody sees it. And the glued area doing it thisway is as good or better than the scarf.My opinion. Bert----- Original Message -----
RE: Pietenpol-List: Fuselage sides
Posted: Sun Oct 17, 2004 2:49 pm
Hi FredI spliced ours at a upright.I scoffed the joint so it is hidden behind the upright.Used a radial arm saw with a sanding disk instead of a blade .Set the saw about 3 degrees of horz.Dale Mpls----- Original Message -----
Posted: Sun Oct 17, 2004 4:54 pm
I dont see that should be a strength issue. Dick ----- Original Message -----
Posted: Sun Oct 17, 2004 5:22 pm
Subject: Re: Pietenpol-List: Fuselage sidesIn a message dated 10/17/2004 2:50:25 PM Central Standard Time, ddjohn(at)earthlink.net writes:Is it okay to splice the fuselage side plywood at an uprightDid mine on a diagonal for more surface. Dale, how did you get yours BEHIND the upright??________________________________________________________________________________
Posted: Sun Oct 17, 2004 7:50 pm
Subject: Re: Pietenpol-List: Fuselage sidesIn a message dated 10/17/04 9:52:28 AM Central Daylight Time, cgalley(at)qcbc.org writes:<< If it is a scarf joint 12 to 1 See AC 43.113-1b for details. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message -----
