Pietenpol-List: Re: Pietenpol-List Digest: 12 Msgs - 11/27/04
Posted: Sun Nov 28, 2004 11:53 pm
Subject: Pietenpol-List: Re: Pietenpol-List Digest: 12 Msgs - 11/27/04Hey, Group, I am ready to build the tail surfaces and have a question about the steel fittings. The plans call for 5/8 x 13 gauge steel. The chart says that13 gauge is .09". Aircraft Spruce sells 5/8 inch strap up to .08" thickness. My understanding is that 4130 is stronger than the mild steel Pietenpol had available. If this is correct, would it be reasonable to use the .08" steel?It involves a considerable savings in labor if it is safe. What say you? Don Cooley________________________________________________________________________________
