Pietenpol-List: Torque Tube Rod
Posted: Wed Dec 08, 2004 6:48 pm
Why does the bolt or rod that some of us have put though our straight though axleshave to be welded? I'm probably missing something obvious but I don't knowwhat. The rod can't jump out of the axle because there is a nut at the bottomthat will prevent it from coming up through the torque tube. Thanks. DavePaulsen ________________________________________________________________________________
RE: Pietenpol-List: Torque Tube Rod
Posted: Thu Dec 09, 2004 7:10 am
Original Posted By: gerryy(at)airage.com (Gerry Yarrish)
Dave,The guide pins don't have to be welded. However, just putting a holethrough the axle causes a stress concentration. My axle broke at the guidepin, but my axle was only .120" wall. My new axle will be .188" wall, and Iwill have it heat treated after welding to raise the yield strength to105,000 psi, which will make it about 50% stronger (and 8 lbs lighter) thana .25" wall axle non-heat treated. I am also going to change the design ofthe guide pins to allow the holes through the axle to be on the neutral axisso any stress concentrations caused by the holes will not matter.Jack PhillipsSlowly beginning to repair NX899JP-----Original Message-----Why does the bolt or rod that some of us have put though our straight thoughaxles have to be welded? I'm probably missing something obvious but I don'tknow what. The rod can't jump out of the axle because there is a nut at thebottom that will prevent it from coming up through the torque tube. Thanks.Dave Paulsen Dave,The guide pins dont have to bewelded. However, just putting a hole through the axle causes a stressconcentration. My axle broke at the guide pin, but my axle was only .120wall. My new axle will be .188 wall, and I will have it heattreated after welding to raise the yield strength to 105,000 psi, which willmake it about 50% stronger (and 8 lbs lighter) than a .25 wall axlenon-heat treated. I am also going to change the design of the guide pinsto allow the holes through the axle to be on the neutral axis so any stressconcentrations caused by the holes will not matter.Jack PhillipsSlowly beginning to repair NX899JP-----Original Message-----Why does the bolt or rod that some of us have putthough our straight though axles have to be welded? I'm probably missingsomething obvious but I don't know what.The rodcan't jump outof the axle because there is a nut at the bottom that will prevent it fromcoming up through the torque tube. Thanks. Dave Paulsen________________________________________________________________________________
Re: Pietenpol-List: Torque Tube Rod
Posted: Thu Dec 09, 2004 6:06 pm
Thanks Jack. Perhaps I will try to find two 8 inch pieces of pipe that can sliptightly into my axle - position them so there's about 4 inches of pipe on eitherside of the holes - and drill them through. This will double the thicknessof the axle in that critical area acting as reinforcement in case there isa exceptionally hard landing.Dave Paulsen ----- Original Message -----
Posted: Fri Dec 10, 2004 12:48 pm
Original Posted By: David Paulsen
Posted: Fri Dec 10, 2004 12:53 pm
--NextPart_Webmail_9m3u9jl4l_5435_1110316130_2 name="P1010024.jpg" filename="P1010024.jpg"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
RE: Pietenpol-List: Torque Tube Rod
Posted: Fri Dec 10, 2004 1:14 pm
Re: Pietenpol-List: Torque Tube Rod
Posted: Fri Dec 10, 2004 4:34 pm
----- Original Message -----
Posted: Tue Mar 08, 2005 3:08 pm
Original Posted By: David Paulsen
John,I am still studying your words of wisdom so when I get to my axle installation,I will have good info to work from. Your comment about "next time using spreaderbars with thicker walls", what did you use and what would you go to?Thanks so much.Alex Sloan-------------- Original message -------------- ----- Original Message -----
Posted: Wed Mar 09, 2005 11:27 am
Original Posted By: alexms1(at)comcast.net
Posted: Wed Mar 09, 2005 12:19 pm
