Pietenpol-List: RE: Testing a rib
Posted: Thu Feb 24, 2005 7:06 am
What is an appropriate method to break a wing rib?I built one tonight using stables to hold the gussets on. When I removed itfrom the jig, I found that there was not enough strength in the stapledjoints to keep the rib in shape. Basically, things were shifting andtwisting. From here on out I will go back to letting the rib cure in thejig. The rib tonight will be scrap, and I would like to bust it.I have had the best results from gluing all of the rib and gussets togetherat one time. Basically, putting a set of gussets into the jig, then all therib sticks, then the other set of gussets. When I put one of the 3 inchsplit PVC clamps on each gusset everything is held firmly. After cure, therib is removed, and everything looks really good. If I don't use that muchpressure, sometimes a stick will not be seated fully, and the gusset willnot have good contact with all of the mating sticks. I am concerned that Imight be putting too much pressure on the T88 and be starving the joint.I tried a rib with Resorcinol so as to not have the pressure concern. Itworked OK, but the T88 made a better looking rib (gap filling).Any insight would be appreciated.Regards-Norm Muzzy________________________________________________________________________________Date: Thu, 24 Feb 2005 08:26:42 -0500
