Pietenpol-List: corvair heads / progress report
Posted: Mon Sep 26, 2005 9:15 pm
Subject: Pietenpol-List: corvair heads / progress reportHey corvair people..When doing a valve job, according the the WW manual, you are to use "wide seats".Does this presume that for every valve job you're replacing the seats? Also,what are people doing for valves? Using new, existing, stainless??I found a local performance engine shop that is pretty good to work with, plusit's 3 miles from my house so I can inspect things at each stage very easily.Dropped the heads off tonight. WW has the crank, distributor and front startercomponents in the works... Clarks has the cylinders, pistons, cam, etc.. Prettysoon I'll have all the parts together for this thing and once I have theengine completed, hopefully that will spur on the rest of the project.Hopefully, by spring the engine will be ready to run and I'll have the fuselageon gear. Then over the summer complete the wings. Man - if all goes well Icould get this thing done in 2-3 more years... Sorry for the rant, just getting wound up again... Besides, tonight I flew the172 and fuel at KMIC is 4.45 / gallon. That equals about $45 / hour in fuelalone. OUCH. I'm setting the Piet up for Auto gas so at least I'll save a bucka gallon.Seeya,Tom B.________________________________________________________________________________
