Pietenpol-List: Straight Axle Landing Gear Fittings
Posted: Wed Nov 30, 2005 8:57 pm
I'm cutting the fittings for the straight axle landing gear and was hoping someonecould help with the dimensions of the inside fitting.The Flying And Glider Manual drawings on page 17 give a dimension of 3/32" fromthe lower bolt holes to the fold line. Obviously this is incorrect, what measurementhave you guys used?Whist we're on the subject, how are the slots for this fitting accurately cut intothe fuse floor?Thanks in advance.Mike GreenRomsey,Victoria,AUSTRALIA.________________________________________________________________________________
Re: Pietenpol-List: Straight Axle Landing Gear Fittings
Posted: Thu Dec 01, 2005 4:34 am
Original Posted By: Mike Green
Distances don't matter, cut it oversized, bend it, clamp it in place, and drillit in place. Don't pre-drill holes, except maybe in one side only as a staringpoint. Exact bolt placement is not that important. Slots can be cut by "chaindrilling" with a small bit and cleaning up with a file. Jigsaw from thebottom works well, too. Make sure you understand how the fittings go, it is notentirely obvious from the drawing until you think about it for a few hours.Gene ----- Original Message -----
Posted: Thu Dec 01, 2005 6:06 am
Original Posted By: harvey rule
Posted: Thu Dec 01, 2005 7:49 am
Subject: Re: Pietenpol-List: Straight Axle Landing Gear Fittingshaven't gotten that far yet but I would think a dremel or rotozip would work wellfor slotting the fuselage.Tom B.________________________________________________________________________________
Re: Pietenpol-List: reason to own your own airplane
Posted: Thu Dec 01, 2005 11:57 am
This is a good article, especially for those of us with youngsters. Well worth reading!http://www.beechaeroclub.org/displayart ... .htmlOscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Subject: Re: Pietenpol-List: reason to own your own airplane owner-pietenpol-list-server(at)matronics.com, pietenpol-list(at)matronics.com, sqrlnet(at)yahoogroups.com
Posted: Thu Dec 01, 2005 1:26 pm
27, 2005) at 12/01/2005 08:26:57 PMGood one, Oscar.Hits close to home too.My two sons can't wait untill the corvair powered pod racer has it's 40hours flown of.Hans________________________________________________________________________________
