Pietenpol-List: pesky elevator cable
Posted: Sun Dec 18, 2005 4:01 pm
Phil mentioned the matter of the elevator cables rubbing the leading edge of the horizontal stabilizer, and that most Piets seem to have that condition. Not John Dilatush's "Mountain Piet"!Check out the pictures at http://www.flysquirrel.net/piets/John_piet.html (second picture from the bottom) and you'll find that engineer John studied the geometries of the bellcranks, hinge points, and cables and built his such that everything stays true as it goes about its "four-bar linkage" motions. This is one fix that should be easy to figure out for those with the luxury of starting from scratch. Myself, with retensioning the tail rigging after the repairs to 41CC, I *almost* started to tension the lower aileron cables to match the uppers, but quickly realized that I'd put the controls in a bind when I pull the stick back if I did that.But they fly just fine with the setup 'per plans' and a section of clear plastic tubing over the upper aileron cables where they contact the LE of the HS to prevent scuffing the paint.Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
