Pietenpol-List: cable going thru the stabilizer
Posted: Tue Dec 20, 2005 5:23 pm
Original Posted By: "John and Phyllis Smoyer"
Re: Pietenpol-List: pesky elevator cable:
Posted: Tue Dec 20, 2005 5:55 pm
Subject: Re: Pietenpol-List: pesky elevator cable:In a message dated 12/20/2005 5:24:56 PM Central Standard Time, jpsmoyer(at)verizon.net writes:One factor that influences the elevator cable's clearance over thestabilizer leading edge is the amount of the elevator's downward deflection.How much down deflection is enough? Maybe the cable doesn't rub the LE atthat angle.Also, in the Piet's I've seen, it doesn't appear that any amount of "up"elevator deflection will cause an interference on the stabilizer?.Anycomments on that observation?John, The fouling of the flipper cables on the L.E. of the stab, is just one part of the observation. You see, in addition to that, there is a difference insymmetry in the bellcrank, and the flipper horns, such that when they are in the neutral position, the bottom cable is slack. When the flippers are in theup, or down position, both the top and bottom cables have no slack in them, but they SHOULD NOT be tight. I always refer to them as 'Flippers', as opposed to 'Elevators'...even at work, dealing with jet planes. The name Elevator is a poor description of what those control surfaces actually do. They are NOT what make the plane go up & down - POWER controls altitude, and PITCH controls airspeed.Chuck G.NX770CG________________________________________________________________________________
