Pietenpol-List: Washout & Rigging
Posted: Sun Feb 19, 2006 8:51 am
Subject: Pietenpol-List: Washout & RiggingIn a message dated 2/18/2006 9:05:06 AM Central Standard Time,BARNSTMR(at)aol.com writes:Tim Willis and I have been discussing a few things off list and lately aboutwashout. For all of you guys with flying Piets,1) how much washout do you have?2) have you ever tried changing it any to see if handling is improved? I recently found an interesting article about the subject. (link below) It isa a NACA report done by engineers at Texas A&M in 1953 using washout tests ona Taylorcraft. (I have been trying to investigate to see if it was myTaylorcraft. It was owned by A&M at that time). Anyway - The tests looked=20attheeffects of washout and slots on lateral control near stall. The washout wasvaried from zero to 8 degrees. They used tufts all across the top surface ofthe wing to detect disturbed airflow. The idea is to have the inboard andcenter section of the wing stall first with the singtips still flying, so thattheailerons remain effective throughout the stall.I believe the NACA report conclusion was that 4 degrees washout was optimalfor the taylorcraft and thus recommended for light planes.http://naca.larc.nasa.gov/reports/1953/ ... mbnail11It might be interesting to consider tests of such on the Piet wing todetermine its optimum. Any thoughts?Terry B.Hey Terry, This is an area of aerodynamics that has always interested me. I triedprinting the pages of that naca report, because it's easier for me to relax=20inthe lazy boy chair to read, but my printer cut off the right side of the page. Here is my understanding on the subject, and what I did:A Hershey bar wing inherently stalls first at the inboard portion of thewing, and washout increases drag. Washout is much more common in Tapered Wings,because they inherently stall the tips first. Therefore, why even rig anywashout in the wing ? Because any slight discrepancies in construction, slighterrors in rigging, and in the event you don't keep the ball in the middle, Isuppose you could stall one wing before the other, albeit a rare occasion. =20Ihave Never felt one tip stall before the other...it always breaks, or actuallyjust Mushes, straight ahead, however, I haven't tried it with the ball way offcenter - at altitude of course. The Pietenpol wing has a fairly sharp leading edge, which causes asharper stall break, than say the ol' T-craft. Have you ever noticed how big theleading edge radius is on an aerobatic plane ? Those wings have a highercritical angle of attack (the angle at which the wing begins to stall), but=20payforit with an increase in drag. They have excess power to overcome the dragpenalty. Nothing is free !! The Pietenpol wing is All about Lift. It createsaLot of lift at airspeeds that the T-craft wing isn't even considering flyingyet. When I was flying in the Test Phase of my plane, I re-rigged my wingseveral times, because I had a slightly Left Wing Heavy condition. I use theplans built 'Lollipop' fittings at the upper lift strut fittings, so when Ire-rigged it was more of an adjustment in Symmetry, as opposed to changing thelength of the lift struts. I came to find that the front strap across the bottomof the fuselage was the primary cause of the left wing heavy condition. Initially I didn't have any bolts through that strap, into the ash cross member.Early on, that strap began to have a gap between it, and the bottom of thefuselage. I thought it was because of the dimension change in the wood with theseason, and couldn't imagine that slight dimension change could cause somewashout, and a wing heavy condition. Came to find the cause was hard landings.Iinstalled a #10 bolt down through the center of the ash cross piece andstrap... Presto !! Most all of the left wing heavy condition disappeared. =20Thenthedarn thing began to show a gap again, between the center, and the left side. I now have three bolts down through the ash cross piece / cross strap, spacedevenly. Hard landings in a Pietenpol are because as you roundout for landing andincrease the angle of attack, the drag increases dramatically and rapidlydecreases the airspeed...as opposed to a sharp stall break. The sharp stall breakjust isn't there in the Pietenpol wing. To conclude, I have about 1/16" to 1/8" washout in my wingtips, whichprobably is about 1=BA or so. The wing is rigged straight (no dihedral), and justslightly err towards washout. Now, instead of testing the 'Runway Hardness',I try to land as softly as a butterfly with sore feet !!Chuck G.NX770CGp.s. them ol' boys from Texas A&M probably got hold of some Federal money togo play around in the sky with the Taylorcraft, learned a Lot, shared theirfindings with us, and I'm sure they had a Lot of Fun !!________________________________________________________________________________
