Re: Pietenpol-List: Cabane info for Tim Willis
Posted: Fri Feb 24, 2006 10:05 pm
Original Posted By: "Roman Bukolt"
Subject: Re: Pietenpol-List: Cabane info for Tim Willis > > In a message dated 2/25/2006 5:51:18 P.M. Central Standard Time, > luther(at)gci.net writes: > > I just took another look at my plans to see where I came up with > my cabane > length, and you are correct, there aren't any definite numbers, > except for the > 2 degree wing incidence. So, then I was wondering where I came > up with my > numbers. > > > > > Please, look carefully and you will find all the dimensions for > building on > the 1934 Hoopman plans. I've read for years builders complaining > and accusing > BHP for publishing incomplete plans. JUST READ. > For your latest (aren't) I refer you to the plan sheet "Complete > wing strut > details for improved air camper" Dated 3-26-34. (That's 5 months > before I rode > in a Model A Ford rumble seat from Shreveport, La to Chicago, Ill > to take in > the 1934 Worlds Fair) 12 yrs old. > This plate (sheet) shows the tail skid details in the upper right > quarter of > the plate. Carefully look to the left of that diagram past two > vertical lines > and you will clearly see the cabane strut outlines. and to the > immediate > left of this you will see two vertical lines with arrows at > either ends stating > Front Strut 21 1/4 and Rear Strut 20 1/4. Need I say more. > I'm in no way attempting to be a smartie as that is the last thing > I am but > I do get a bit tired of those who want to critique the old plans > as they are > lacking. Mr Piet and Hoop assumed that most attempting to build an > aircraft > knew how to read mechanical drawings and professed enough > mechanical ability to > choose and use proper hand and mechanical tools. > > Someone who hopes he can finish what he has started > ________________________________________________________________________________
