Pietenpol-List: Model A radiator location
Posted: Wed Apr 19, 2006 9:41 am
Original Posted By: "Brown Gravy"
Oh I didn't notice that one. I have been referring to the Sky Scout drawings forthe wing bracing, so I hopefully I've drawn it correctly.The wing section shown for the Air Camper isn't complete enough to construct theribs. That's the reason for checking the Sky Scout drawings.The ordinates given for the airfoil plot out in a less than smooth curve to put it mildly, so I searched online for a more carefully composed set of points to enter into CAD. The Holcomb's Aerodrome web page gives a set of ordinates that create a smooth curve when a spline is drawn between then. They provide the ordingates in either XLS or text format. If anyone is interested here's the page:
http://www.airminded.net/piet/piet.htmlRead this topic online here:
http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Model A radiator location
Posted: Wed Apr 19, 2006 9:52 am
Has anyone tried an alternate location for the radiator on Model A powered Piets?Is it possible to locate it below the engine at an angle that follows the originalcowling design?Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 19 Apr 2006 07:53:57 -0700
RE: Pietenpol-List: Model A radiator location
Posted: Wed Apr 19, 2006 10:15 am
Posted: Wed Apr 19, 2006 12:35 pm
Pietenpol-List: Re: Model A radiator location
Posted: Wed Apr 19, 2006 2:17 pm
Original Posted By: harvey rule
That's what I had in mind. But before I decide the plane should revolve aroundthis alternate cooling arrangement I should ask: Is the lack of forward visabilitydue to the radiator mounted above the engine a real issue? I like the lookof the radiator above the engine. It works with the lines of the plane.Read this topic online here:
http://forums.matronics.com/viewtopic.p ... ______Date: Wed, 19 Apr 2006 15:31:20 -0400
RE: Pietenpol-List: Re: Model A radiator location
Posted: Wed Apr 19, 2006 2:35 pm
Posted: Wed Apr 19, 2006 2:56 pm
Re: Pietenpol-List: Model A radiator location
Posted: Wed Apr 19, 2006 8:03 pm
Original Posted By: Brown Gravy
Sure they have, the sky scout has it mounted on the lower cowl exactly as you suggest.Gene ----- Original Message -----
Re: Pietenpol-List: Re: Model A radiator location
Posted: Wed Apr 19, 2006 11:42 pm
Subject: Re: Pietenpol-List: Re: Model A radiator locationIn a message dated 4/19/2006 2:20:49 PM Central Standard Time, mjs.browngravy(at)yahoo.com writes:Is the lack of forward visability due to the radiator mounted above the engine a real issue?I've got about 23 hours of flying behind the radiator of a Model A engine, and it is not an issue, as far as visibility is concerened. However,I had my radiator custom built to be the width between the fwd cabane struts, and about1/3 of the way down, leaving some visibility under the radiator. The top tankwas behind the leading edge of the wing, in a cavity that I built in the bottom of the wing. I have lots of pics & text on this page of my web site:
http://nx770cg.com/ModelAEngine.htmlChuck G.NX770CG________________________________________________________________________________Date: Thu, 20 Apr 2006 00:31:17 -0700
Posted: Thu Apr 20, 2006 7:16 am
Subject: Re: Pietenpol-List: Model A radiator locationThe radiator that Bernard mounted under the engine was used only on the Model A powered Scout...it worked really well... I restored the airplane about 40 years ago and it is still flying today. I doubt that it could be made to workon an Air Camper, because the firewall is vertical...on the Model A Scout, thefirewall slanted back, allowing the cooling air from the radiator to travel up and back to exit through louvers on the top cowl ahead of the instrument panel. Bernard didn't "reject" the radiator installation...he just didn't buildany more single place airplanes.Forrest LovleyJordan MN________________________________________________________________________________Date: Thu, 20 Apr 2006 09:38:12 -0400
Posted: Thu Apr 20, 2006 9:21 am
