Pietenpol-List: Here's the rib comparison
Posted: Thu Apr 20, 2006 2:16 pm
Original Posted By: Ken
Here's an AutoCAD drawing containing an overlay of the ordinates found on http://www.airminded.net/piet/piet.html and the dimensons given in the F&G manual. Unless I totally screwed up entering the dimensions from the F&G manual they are either less than perfect or it's a brilliant airfoil of some sort. You all take a look. The cayn line with the yellow circles is the F&G airfoil and the Red spline was generated from the ordinates found at the above site.AutoCAD drawing viewers are easy to find as freeware. I tested the drawing file with the free viewer found at http://www.infograph.com/products/dwgviewer/(remember you take responsability for you own downloads). Anyway, the drawing fileis attached.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ______Date: Thu, 20 Apr 2006 15:20:08 -0400
RE: Pietenpol-List: Here's the rib comparison
Posted: Thu Apr 20, 2006 3:00 pm
Hi BGIs the file attached to the piet site or one of the others? Looking forwardto comparing the two. Did you put the spars in?Best regardsSteve G-----Original Message-----
Pietenpol-List: Re: Here's the rib comparison
Posted: Thu Apr 20, 2006 3:10 pm
Original Posted By: "Brown Gravy"
I really don't know where the file ended up. I simply attached the file when Iwrote the message.I didn't attach the spars. It's only a comparison of the curve. I didn't includethe spars or other membersbecause I haven't received my plans yet and I don'twant anyone using my drawing to locate critical members.Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Here's the rib comparison
RE: Pietenpol-List: Re: Here's the rib comparison
Posted: Thu Apr 20, 2006 3:17 pm
Perhaps it wasn't allowed and was deleted?Read this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: RE: Pietenpol-List: Re: Here's the rib comparisonDate: Thu, 20 Apr 2006 17:12:10 -0400
