Pietenpol-List: Corvair Engine Cases
Posted: Mon May 01, 2006 9:19 am
Original Posted By: "Egan, John"
Re: Pietenpol-List: Corvair Engine Cases
Posted: Mon May 01, 2006 9:36 am
The cases are the same as long as they are both 164 cu inJim Dallas>From: "Egan, John" >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Corvair Engine Cases>Date: Mon, 1 May 2006 09:19:21 -0500>>Hi,>>>I have a question regarding Corvair engine cases. I have two stock>engines. I have a "RH" at 110 hp and a "RG" at 95 hp engine. Do you>guys know if the cases are the same? Do the heads distinguish the horse>power or is the case also a factor? The reason I'm asking is that I>would like to use the best of the two cases if they are the same. I>realize I need to use the heads from the "RH" engine if I want the>desired 110 hp. I have the conversion manual and I don't find specific>information on this subject in it. This is planned to go in my Piet>project, so I thought some of you guys may know the answer to this.>>>Thank you for other recent help too.>>>John>>>This e-mail is intended for the use of the addressee(s) only and may >contain privileged, confidential, or proprietary information that is exempt >from disclosure under law. If you have received this message in error, >please inform us promptly by reply e-mail, then delete the e-mail and >destroy any printed copy. Thank you.>________________________________________________________________________________Subject: Re: Pietenpol-List: Corvair Engine Cases
Posted: Mon May 01, 2006 10:20 am
John,Both are '65 cases and the same, the camshaft and head make the HPdifference.Cases prior to '65 are slightly differentHans________________________________________________________________________________Date: Mon, 1 May 2006 09:11:46 -0700
Re: Pietenpol-List: Wing tip brace question
Posted: Mon May 01, 2006 4:17 pm
Use a horseshoe-shaped piece of 1/4" plywood glued to the spar face andposition the end of the 1/2" x 1/2" brace in the 1/2" x 1/2" opening ofthe "horseshoe". This setup captures the brace and the relatively-large glued surfaceagainst the spar face provides lots of shear strength. It has workedfine on my Pietenpol for nearly 36 years.A simple butt joint will not work, against the spar face or against theinside of the tip bow, where extra glued area will be needed to hold thebrace in position against fabric tension.Graham Hansen Pietenpol CF-AUN________________________________________________________________________________Date: Mon, 1 May 2006 15:46:57 -0700
