Pietenpol-List: Adding lightness
Posted: Wed Jun 28, 2006 8:45 am
Subject: Pietenpol-List: Adding lightnessHi everybody.As I am still compiling information and have not started building I'm wondering how to build light.I wonder if anybody has done a spreadsheet on weights. I have seen some weights for tails wings and fuselage but what about the little parts. Instruments wheels landing gear etc.What are you builders thoughts if you had to build again to minimize weight what would you target?Wood is the first thing but the glue and gusssets are what they are. I thought of rounding off all the stringers and longerons, improves looks, helps varnish stick, looks better shaves. some weight. Build short tail standard width minimum fuel tank and instruments. I would think finish is a big area of possible savings and always weight watchers for the pilot.What are the top ten things to do to add lightness. Lets hear your thoughts.Steve in Maine________________________________________________________________________________
