Pietenpol-List: Phone number for Jim Corder (Hegy Props)
Posted: Wed Oct 25, 2006 8:09 pm
Hi Pieters,Does anyone have Jim Corder's phone number (of Hegy prop fame)? I've found severalold references on the 'net that sounds like he moved from Marfa to somewhereelse, & I can't find a current email address or phone number.Have a beautiful 72 x 42 Hegy on the A-75, turns 2150-2200 on climbout and topsout at 2400, so this prop is better suited for the A-65. I'd like to get therpm's up around 2400-2500 on climbout so it will run like the A-75 that it is.Thanks in advance,Dave MordecaiPanacea, FLNX520SFHi Pieters,Does anyone have Jim Corder's phone number (of Hegy prop fame)?  I've foundseveral old references on the 'net that sounds like he moved from Marfa tosomewhere else, & I can't find a current email address or phone number.Have a beautiful 72 x 42 Hegy on the A-75, turns 2150-2200 on climbout and topsout at 2400, so this prop is better suited for the A-65. I'd like toget the rpm's up around 2400-2500 on climbout so it will run like the A-75that it is.Thanks in advance,Dave MordecaiPanacea, FLNX520SF________________________________________________________________________________Date: Wed, 25 Oct 2006 20:16:07 -0700
Re: Pietenpol-List: Phone number for Jim Corder (Hegy Props)
Posted: Thu Oct 26, 2006 7:45 am
Subject: Re: Pietenpol-List: Phone number for Jim Corder (Hegy Props)Dave,You can find Jim at; 200 S 6th, Olathe, Co 81425. 970-323-6341. IF you can catch him. He builds beautiful and efficient propellers but it will require time and patience on your part.Nathan________________________________________________________________________________
RE: Pietenpol-List: Looking for wood
Posted: Thu Oct 26, 2006 8:06 am
Chet wrote->I have a Ford Model A engine with a Slick mag model number 4032 left>hand with a serial number 401006. I need a cross referance list number>for a replacement mag.I couldn't quickly Google up that model number, but Harry Fenton offers this info that you might try:>Unison Industries values feedback and encourages customers to contact>the Slick Customer Service Department to obtain information on the products>that they manufacture. For quick access to product support, contact the >Unison>Industries/Slick Aircraft Products Customer Service Department in Rockford, >Il;>(815) 965-4700, ext. 143; Fax: 815-965-2457; >E-mail:Todd(at)UnisonIndustries.com.Be sure to tell them it's for a farm tractor ;o)Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net_________________________________________________________________Live Search! ________________________________________________________________________________Subject: RE: Pietenpol-List: Looking for woodDate: Thu, 26 Oct 2006 09:52:08 -0400
Re: Pietenpol-List: Looking for wood
Posted: Thu Oct 26, 2006 9:54 am
Posted: Thu Oct 26, 2006 10:17 am
Original Posted By: TJ Brown
Posted: Thu Oct 26, 2006 11:00 am
Original Posted By: Jdavis2a(at)wmconnect.com
To everything that Jack said about Doug fir, I can wholeheartedly agree except the smell. I like the smell of it except when you put it on the sander and burn it. And I had access to a planer to work it to the dimension I needed so that was not an issue. I will also add that the grain layers (or whatever you want to call them) alternate very drastically between the hard growth ring and the softer material in between, so when you drill a hole through it the bit tends to want to follow the grain and not your intended line. It's hard to drill a straight, clean hole with a small diameter bit when you're not drilling perpendicular to the growth rings (as if you were drilling right into a tree trunk, if you get my drift).And you would think that a company with the name "Aircraft Spruce" would highlight their service in that product! Over on the KRNet, many have said that they prefer to work with Wicks for wood. And if you're in the PacNW there are a few more sources that aren't readily available to others, unless you can reduce the shipping cost. I've heard that Edensaw ( http://www.edensaw.com/ ) is a good one but I have not dealt with them personally.Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net_________________________________________________________________Get FREE company branded e-mail accounts and business Web site from Microsoft Office Live http://clk.atdmt.com/MRT/go/mcrssaub005 ... __________
Posted: Thu Oct 26, 2006 11:15 am
Subject: Re: Pietenpol-List: Looking for woodMy Piet is also built completely of Douglas Fir and came in at an empty weight of 615 lbs. with a corvair engine. You can build a light airplane withfir if you avoid too many additions and "improvements" and watch the number of coats on the fabric. Mine has been flying since 95. Have fun, it was a greatprodjectJIM________________________________________________________________________________Date: Thu, 26 Oct 2006 09:48:15 -0700 (PDT)
Posted: Thu Oct 26, 2006 11:59 am
