Pietenpol-List: Click and laugh
Posted: Tue Dec 12, 2006 5:11 pm
Original Posted By: "Alan Lyscars"
Subject: Pietenpol-List: Click and laugh_Document sans nom_ (
http://pageperso.aol.fr/marcbrecy/deanmartin.html) ________________________________________________________________________________
Re: Pietenpol-List: Wing Ribs
Posted: Tue Dec 12, 2006 5:18 pm
Original Posted By: "Ben Ramler"
Ben,I'm building an Aircamper here in Maine. Just starting with ribs thiswinter.Be careful with "paste-type" epoxies. You'll want the glue to flow into thejoint. Also, the pot life on the Fasco is pretty short.Al----- Original Message -----
Re: Pietenpol-List: Re: Aircamper Valve Covers
Posted: Tue Dec 12, 2006 5:34 pm
Original Posted By: "DJ Vegh"
Subject: Re: Pietenpol-List: Re: Aircamper Valve CoversIn a message dated 12/12/2006 6:12:20 P.M. Eastern Standard Time, minoxphotographer(at)yahoo.com writes:I just wrote to the fella who was selling them, and the reply Ireceived a week or so ago states:"I have stopped making the Air Camper valve covers. The foundry thatwas casting them for me found out they were going on airplanes andrefused to make anymore"So, there ya go. Gonna be a long time till I need any, but reallywanted a pair!Tim in BoveyThis is exactly why, when I farm out any work, I lie and tell them it is for something other than an aircraft or that the part will be used on a static display.Ron________________________________________________________________________________
Posted: Tue Dec 12, 2006 5:59 pm
Original Posted By: Pietsrneat(at)aol.com
wow... I'm glad I got mine when I did! ----- Original Message -----
Posted: Tue Dec 12, 2006 6:31 pm
Posted: Tue Dec 12, 2006 6:40 pm
Posted: Tue Dec 12, 2006 6:48 pm
Pietenpol-List: Re: NX421GN Has Airworthiness Certificate !
Posted: Tue Dec 12, 2006 7:03 pm
Subject: Re: Pietenpol-List: Wing RibsIn a message dated 12/12/2006 7:50:53 P.M. Eastern Standard Time, ben_ramler2002(at)yahoo.com writes:Group,so once everything has dried I can remove the staples? this is good info I am getting. So I understand this Once the gussets are stapled in place I can go ahead and remove the rib from jig and do another? I'm just checking to makesure I understand. Does hurt anything If I leave the staples in?Brain likes good info.take care,BenBen, One great tip Mike Cuy gave me years ago: Put "cling"-type wrap down over your jig before each you start each rib.This keeps the rib from sticking to the jig, and the wrap peels right off the rib itself...even after the glue isdry. Works super good. I got industrial sized roll at Sam's club, like they use at deli or cafeterias.Ron________________________________________________________________________________Subject: Pietenpol-List: Re: NX421GN Has Airworthiness Certificate !
Posted: Tue Dec 12, 2006 7:41 pm
Very nice job! Green is great. Talk to as many Pietenpol/GN-1 pilots as you canabout flying it before you actually do, no sweat though! Good Luck!Don EmchNX899DERead this topic online here:
Posted: Tue Dec 12, 2006 7:42 pm
BenI tend to like things the easy way. I bought a reject 36"x80 hollow core door from Menards for $5. I traced lines for 4 ribs at a time on one side of the door. After I was done building ribe, I laid out the tail section on the other side.For ribs, I laid wax paper under all glue areas. To start with, I used a stapler, but pulling staples is a pain. I bought a box of thumb tacks with the plastic ends. Easy to put in and easy to take out. This is assuming you are using T-88 and don't need the pressure that Recorsinol requires. As far as small inconsistancies from 4 moulds, I clamp them all together in the end and run the belt sander over the whole lot.Dick N.----- Original Message -----
Pietenpol-List: Re: Cold weather head gear
Posted: Tue Dec 12, 2006 7:52 pm
I wear a WWII leather helmet I bought on ebay and goggles from aircraft spruce.I actually have 2 different helmets. One has a brow flap and the other doesn't.Without the flap my forehead gets numb down into the forties. If you arelooking for one make sure it has that flap, it makes a huge difference. Witha few layers underneath, the good helmet, goggles and a thick lined leathercoat with a big flip up collar I'm good down into the low 30's. Flew off of thesnow a few days ago!Don EmchNX899DERead this topic online here:
Re: Pietenpol-List: Cold weather head gear
Posted: Tue Dec 12, 2006 7:54 pm
Original Posted By: Gene & Tammy
GeneOne good addition is a hat liner for a cowboy hat to go under your helmet. You should be able to find them in a western wear store. They are Thinsulate. I wore mine under the hunting hat, kept nice and warm. Also, there are hand and foot warmer packs you can get, they are one time use, about $1 pair.Dick N. ----- Original Message -----
Posted: Tue Dec 12, 2006 7:56 pm
Gene, Check out this link. It is in the UK, but it sure looks like nice equipment....
http://www.flyingjacket.com/DB ----- Original Message -----
Posted: Tue Dec 12, 2006 8:26 pm
Original Posted By: Malcolmbru(at)aol.com
Maybe Pat Panzerra will trade you his "Air Camper" ones from his beautiful red show engine for another nice pair. I don't think he's going to put that on a Piet.Hmmm... I wrote that mostly in jest but, hey, you never know???Eric>From: Tim Verthein >Reply-To: pietenpol-list(at)matronics.com>To: pietenpol-list(at)matronics.com>Subject: Pietenpol-List: Re: Aircamper Valve Covers>Date: Tue, 12 Dec 2006 15:09:44 -0800 (PST)>>>>I just wrote to the fella who was selling them, and the reply I>received a week or so ago states:>>"I have stopped making the Air Camper valve covers. The foundry that>was casting them for me found out they were going on airplanes and>refused to make anymore">>So, there ya go. Gonna be a long time till I need any, but really>wanted a pair!>>Tim in Bovey>>"I am wondering if the Corvair "Aircamper" valve covers are still>available. I called the number listed on :>
http://users.aol.com/bpabpa7315/tm.html. , but it was disconnected.>> Thanks in advance for any help you can give.">>==>You *can* repair a flip-flop with a capacitor!>==>>>Have a burning question?>Go to
www.Answers.yahoo.com and get answers from real people who know.>>________________________________________________________________________________
