Pietenpol-List: Model A Eng Timming
Posted: Sat Dec 23, 2006 8:22 am
Original Posted By: Gene Beenenga
Hello:I'm having trouble timing my model A engine. With a slick mag that has a 25 degree inpulse. I have set the mag so the points will open at 25 degrees BTDC. AIso I have set the timing with out the inpulse engaged. But when I turn the prop over to check the inpulse it will snap about 45 degrees after TDC. Any and all ideas will be greatly appreciated.Chet________________________________________________________________________________Date: Sat, 23 Dec 2006 08:30:39 -0600 (GMT-06:00)
