RE: Pietenpol-List: Fuel tanks and baffels
Posted: Mon Jan 29, 2007 3:06 am
Subject: Pietenpol-List: Fuel tanks > I'm checking into building a new fuel tank for my Piet. What > grade of aluminum should I use? Has anyone used any other metal > for their tanks? I could use extra weight up front so the weight > is not a negative factor. I'm changing from a metal prop to a wood > one, a loss of about 12 lbs Plus when I pulled my old tank I found > 16 lbs of lead the builder had installed in front of the tank. > I'm going to mount a battery and a tool box on the firewall and > that will help some. > Thanks > Gene________________________________________________________________________________Subject: RE: Pietenpol-List: Fuel tanks and baffelsDate: Tue, 30 Jan 2007 11:40:00 -0500
