Pietenpol-List: 17 gallon nose tank, no baffles
Posted: Tue Jan 30, 2007 1:00 pm
Re: Pietenpol-List: 17 gallon nose tank, no baffles
Posted: Tue Jan 30, 2007 1:28 pm
MikeThe tank I removed from my Piet is almost an exact copy of your drawing! The only difference I noticed is the stainless strap. I'm not sure of the thickness of the tank. I've even considered just plateing over the tank. I'm going to take the tank to someone knowledgable to see what they say. In the end, it'll be me that makes the decision on what to do and it will be me flying with it. Everyones input has been really helpful. I'm learning a lotThanks for the heads up on the Fuel Lube and yes, teflon tape is a good thing to keep away from fuel or oil. All it takes is one little ol' piece to shut you down in a big way (been there/done that with a P/U truck engine).ThanksGene----- Original Message -----
Posted: Tue Jan 30, 2007 2:19 pm
Posted: Tue Jan 30, 2007 9:18 pm
Walt,What did you use for the female threaded fittings in your tank? ...and did you thread AL pipe into it for your cap/gas gauge? Just wondering if once you use Al for the tank if you must use Al all around due to chemical reactions between metals.Glenn W. ThomasStorrs, CThttp://www.flyingwood.com----- Original Message -----
Posted: Wed Jan 31, 2007 8:15 pm
Original Posted By: "GlennThomas(at)flyingwood.com"
You should probably order the 3/8" welding flange. Then you can install the finger strainer in the tank and that has a 1/4" finished thread.Dick N.----- Original Message -----
