Pietenpol-List: Step question and Helmet cam information
Posted: Fri Mar 02, 2007 9:36 am
Original Posted By: "Bill Princell"
Posted: Fri Mar 02, 2007 10:43 am
I have a few pics of this ;I will see if I can send them along. I will have to send this letter to outlook first,sympatico doesn't want to accept the pics as attachments.>From: "KMHeide, BA, CPO, FAAOP" >Reply-To: pietenpol-list(at)matronics.com>To: Pietenpol >Subject: Pietenpol-List: Step question and Helmet cam information>Date: Fri, 2 Mar 2007 07:22:44 -0800 (PST)>>Members of the list:>> I am interested in photos and designs of a step inserted in the fuse for >the rear pilot to gain access into and out of the rear cockpit. I thought I >had seen a photo of one whereas you insert foot into the made opening and >then step up and into the cockpit. I believe it was located back around the >rear seat. Make sense?!? Interested in this approach and its' design. Any >assistance is greatly appreciated. I know marine boats have a similar >design which is made out of metal that you just cut and install in place.>> AND........>> Here is the information on my helmet cam purchased at Shopko. You may >just try and find the manufacturer and see what other stores carry this >set-up.>> Model ATC2K Water Resistant Hands Free Helmet Cam with Flash Memory >Video Recorder. 640x480 VGA resolution @ 30 frames per second. USB and RCA >cables included. Playback on PC or TV. Plug and play direct. 32 MB internal >memory w/expandable up to 2 GB with SD card(not included) mounts easily on >helmets and a wide array of sports equipment. Needs windows XP or Windows >2000.>> Ken H> Fargo, ND> Company is Oregon Scientific, Inc. Tualatin, Oregon 1-800-853-8883 >www.oregonscientific.com>>>--------------------------------->Never Miss an Email>Stay connected with Yahoo! Mail on your mobile. Get started!________________________________________________________________________________
Posted: Fri Mar 02, 2007 11:28 am
Ok I finally figured out how to get you those pics.The aluninum box that a friend of mine made up for me looks like this" >" from the side.I don't have a pic of it but you can see the top view from behide the seat in one of the pics.He also made the the horseshoe bracket that holds the whole thing in place .The box has a flange on it so the horseshoe bracket can hold it.There are two horseshoe brackets ,one for the inside and one for the outside.They bolt together with short bolts and nuts.I only use my toe to get in.The whole foot will not fit in the box,but it is enough to get the leverage in order to get in.I put a rubber bottom on it to take the wear,made out of the side of a rubber boot cut to shape and glued in.You can use either foot.I also put in a flop door as you can see.Pryor to this I had to do the limbo to get in,now I just step right in there easy as pie. Most of this work was done by friends of mine helpng me.I watched and learned from the masters.I hope this helps a little.From the pics you can see the positioning of the box.I have seen in other pics from other sites boxs made out of wood and they look quite good and that is where I found out where to put the box.I will see if I can find those sites again and if I find it I will send it along.>From: "KMHeide, BA, CPO, FAAOP" >Reply-To: pietenpol-list(at)matronics.com>To: Pietenpol >Subject: Pietenpol-List: Step question and Helmet cam information>Date: Fri, 2 Mar 2007 07:22:44 -0800 (PST)>>Members of the list:>> I am interested in photos and designs of a step inserted in the fuse for >the rear pilot to gain access into and out of the rear cockpit. I thought I >had seen a photo of one whereas you insert foot into the made opening and >then step up and into the cockpit. I believe it was located back around the >rear seat. Make sense?!? Interested in this approach and its' design. Any >assistance is greatly appreciated. I know marine boats have a similar >design which is made out of metal that you just cut and install in place.>> AND........>> Here is the information on my helmet cam purchased at Shopko. You may >just try and find the manufacturer and see what other stores carry this >set-up.>> Model ATC2K Water Resistant Hands Free Helmet Cam with Flash Memory >Video Recorder. 640x480 VGA resolution @ 30 frames per second. USB and RCA >cables included. Playback on PC or TV. Plug and play direct. 32 MB internal >memory w/expandable up to 2 GB with SD card(not included) mounts easily on >helmets and a wide array of sports equipment. Needs windows XP or Windows >2000.>> Ken H> Fargo, ND> Company is Oregon Scientific, Inc. Tualatin, Oregon 1-800-853-8883 >www.oregonscientific.com>>>--------------------------------->Never Miss an Email>Stay connected with Yahoo! Mail on your mobile. Get started!________________________________________________________________________________
Posted: Fri Mar 02, 2007 12:02 pm
Ok I found the web page and the pics of the wooden box step;the web page is www.cpc-world.com and I retrieved a few pics for you off it;see attachments.Enjoy.By the way from this guys web page you get a lot of info on how to build a piet but he is only one of many.His stuff looks good though.>From: "KMHeide, BA, CPO, FAAOP" >Reply-To: pietenpol-list(at)matronics.com>To: Pietenpol >Subject: Pietenpol-List: Step question and Helmet cam information>Date: Fri, 2 Mar 2007 07:22:44 -0800 (PST)>>Members of the list:>> I am interested in photos and designs of a step inserted in the fuse for >the rear pilot to gain access into and out of the rear cockpit. I thought I >had seen a photo of one whereas you insert foot into the made opening and >then step up and into the cockpit. I believe it was located back around the >rear seat. Make sense?!? Interested in this approach and its' design. Any >assistance is greatly appreciated. I know marine boats have a similar >design which is made out of metal that you just cut and install in place.>> AND........>> Here is the information on my helmet cam purchased at Shopko. You may >just try and find the manufacturer and see what other stores carry this >set-up.>> Model ATC2K Water Resistant Hands Free Helmet Cam with Flash Memory >Video Recorder. 640x480 VGA resolution @ 30 frames per second. USB and RCA >cables included. Playback on PC or TV. Plug and play direct. 32 MB internal >memory w/expandable up to 2 GB with SD card(not included) mounts easily on >helmets and a wide array of sports equipment. Needs windows XP or Windows >2000.>> Ken H> Fargo, ND> Company is Oregon Scientific, Inc. Tualatin, Oregon 1-800-853-8883 >www.oregonscientific.com>>>--------------------------------->Never Miss an Email>Stay connected with Yahoo! Mail on your mobile. Get started!________________________________________________________________________________Date: Fri, 2 Mar 2007 10:30:41 -0800 (PST)
Re: Pietenpol-List: Step question and Helmet cam information
Posted: Fri Mar 02, 2007 9:15 pm
