Pietenpol-List: weight of NX41CC
Posted: Sat Jun 30, 2007 5:51 pm
Per digital race car scales, with 3 qts. oil and any unusable fuel, 41CC weighs 633 lbs.I don't believe in weighing without unusable fuel and minimum operating oil, and consider it to be part of the basic empty weight.I weigh 151 lbs. according to the same scales, before I drank a beer and after I drained my internal tank. Prior to doing the W&B I flew 0.6 hrs. to burn off some fuel in the airplane's tank, drained the rest, and did the W&B. Also checked the mechanical tach against a digital "True Tach" and found the following:RPM- mechanical tach/digital tach1000/9001500/13302000/18402200/2000This explains why I can set power in level cruise and exceed redline (2250 RPM) on this engine so easily... it's reading about 200 RPM high when in that range. Now I know I can safely cruise it at 2450 indicated, which is where it likes to cruise anyway. With this prop I really need an A75 to take full advantage ;o)Another delightful day of playing with the Pietenpol!Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net_________________________________________________________________Picture this share your photos and you could win big! http://www.GETREALPhotoContest.com?ocid ... __________
