RE: Pietenpol-List: flying to Brodhead is like having a baby
Posted: Thu Nov 29, 2007 3:09 pm
Posted: Thu Nov 29, 2007 3:59 pm
Posted: Thu Nov 29, 2007 8:30 pm
Re: Pietenpol-List: final rigging
Posted: Thu Nov 29, 2007 8:58 pm
Hi RobertI just did that in August. First it is most important to make sure that the wings are even, measured to the tail. I used the trailing edge at the point that the ailereons start and measured to the base of the vert stab. Make sure that your cabane cross wires are good and tight.I bought a digital level that measures down to the tenth of a degree. I leveled up the fuse and adjusted the struts so the wing tips are 1/2 degree higher than inboard measurement..good luckDick N. ----- Original Message -----
Posted: Fri Nov 30, 2007 6:26 am
Posted: Fri Nov 30, 2007 2:39 pm
Posted: Fri Apr 28, 2017 9:32 pm
>>There are two radio choices that fit in a small instrument hole (2 3/8"?).>These are the Microaire, and the Becker. I have the Becker in my Aeronca >and it> works well. It takes only 5 amps I believe.>>Dan Helsper>Poplar Grove, IL.>>>**************************************Check out AOL's list of 2007's >hottest>products.>(
http://money.aol.com/special/hot-produc ... 0000000001)Kenneth M. Heide, BA, CPO, FAAOP ---------------------------------Get easy, one-click access to your favorites. Make Yahoo! your homepage.________________________________________________________________________________Subject: Pietenpol-List: flying to Brodhead is like having a babyDate: Thu, 29 Nov 2007 14:09:38 -0600
