Pietenpol-List: Sources for wing struts
Posted: Fri Dec 07, 2007 10:57 am
Original Posted By: Ryan Michals
Subject: Pietenpol-List: Sources for wing strutsListers, I've haunted eBay, contacted Wentworth Aircraft in Illinois, and several aviation salvage yards and local FBOs looking for suitable used wing struts, particularly J-series Pipers or possible Taylorcraft. I understand thatfailed struts with the problem area at the bottom or inboard area can still be used for a Piet because the Piet uses shorter struts and the bad area can simply be cut off. Does anyone have, or does anyone know where I might find four struts? I could buy the streamline tube from AS&S but that looks to be about $800 at current steel prices. Matt Paxton**************************************Check out AOL's list of 2007's hottest products.(http://money.aol.com/special/hot-produc ... 0000000001)________________________________________________________________________________Date: Fri, 7 Dec 2007 12:07:21 -0800 (PST)
Re: Pietenpol-List: Sources for wing struts
Posted: Fri Dec 07, 2007 2:22 pm
Original Posted By: Woodflier(at)aol.com
Wood flier,The Piper Colt and TriPacer had the same lower end strut rusting problem. Wasn't aware you could cut-off and still be usable, be very careful with that idea. The AD that came out in the 70's regarding this these struts should be cked-out before you buy. I had to replace the struts on my ole Colt many many years ago and saw the amount of rust damage they had on the lower end. When you can push a fabric testing punch thru 4130 steel (the original AD's testing method), you gotta worry about the entire strutt.Gordon ----- Original Message -----
RE: Pietenpol-List: Sources for wing struts
Posted: Fri Dec 07, 2007 3:12 pm
The rust is generally on the lower end because that is where the watergathers. If you are cutting the bottom off to shorten it you will get agood view of the inside.In reality though, there are lots of the non-sealed struts out there cheapthat don't have any rust and I would wait for some good ones before I usedrusty ones. Most people get tired of having to pay for the repetative ADand just buy new sealed struts when the old ones are still good.Post a message on www.shortwing.org/forum or one of the Cub forums and youshould find some.Brian KrautEngineering Alternatives, Inc.www.engalt.com -----Original Message-----
Posted: Fri Dec 07, 2007 6:11 pm
Pietenpol-List: Re: Sources for wing struts
Posted: Sun Dec 09, 2007 6:13 pm
Original Posted By: "skellytownflyer"
gbowen(at)ptialaska.net wrote:> Mike, little off topic for wood laminations and Pietenpols but if you'd > like to try a rubber modified laminating resin system (off the shelf), that > has some of the best properties for handlaminates try Hexcel's (now > HBFuller) 2315. Think Epoxical (now Endurance in St.Paul) making same > formula. First it's based on a bis-F epoxy but this epoxy is pre-adducted > with Hycar rubber. The liquid rubber precips out when cured and makes a two> phase laminate. Our test, before HB Fuller bought-out the Resins group, > indicated this was one of our best systems. I used it on my Cozy IV, 60 min> gel time, kinda hot exotherm when floxed too thick, but best stuff for > laminates that need to resist flex cracking. Scaled Composites used a bunch> of it for their contract drones work.> GordonThat is exactly the type of adhesive system we used to make, and yeah the rubbermodifiers when used right sure do wonders for mechanicals. We used a varietyof aliphatic amine curatives, 3 in particular, blended in varying proportionsfor different jobs, but in general so that cure rate was as rapid as possiblewithout excessive exotherm. The basic blends were epoxy resin (Dow 362), Hycar,reactive diluent, wetting agent and defoamer, plus silica and fumed silicain the structural adhesive variations, both flowable and thixotropic.Now that I don't do that gig anymore, it's good to know a commercial system existswith the same formulating goals in mind.--------Piet-builder-who-hopes-to-be-flying-next-summerRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: Sources for wing struts
Posted: Mon Dec 10, 2007 7:07 pm
There are a lot of Piper guys in the Shortwing Piper group that have old strutsthat they would like to sell.I don't have any names right now,but if you can'tlocate some I might be able to get you one or two.I sold my Tri-pacer last month.wepulled the struts and took out the lower fork ends and checked them outgood-found no rust,oiled them and put them back.not sure how the lengths workout-was going to see if they would work on the GN-1 but never got around toit.mine has aluminum struts but I would sleep better if I knew they were equalin strength to the steel struts called for.they may be but I have not seen anydocumentation on them.but several are using aluminum.RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
