Pietenpol-List: cowling construction
Posted: Sat Dec 15, 2007 10:13 am
I'm with Gordon and the others... it makes more sense to add stiffeners where needed rather than making the whole piece heavier with multiple layers of glass to add stiffness. It was easy to do with the belly of my Flying Squirrel, for example... look at the 4th through 6th photos on this page - http://www.flysquirrel.net/update.htmlAll you have to do is lay some foam wedges inbetween the layers, or even add them after you've made the cowling and pull it from the mold to see where you need additional stiffness. It's amazing how much rigidity that 3rd dimension can add to a flat layup.One other thing that people have told me is to use peel-ply on your layup (assuming you're laying up over a male plug). It absorbs excess resin as well as providing a much nicer surface to do final finishing on once you peel it off. Work in a warm area, too... working when it's cool means you'll be using more resin to get it to wet out the plies. Use your squeegee. Epoxy resin is heavy!Oscar ZunigaSan Antonio, TXmailto: taildrags@hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Date: Sat, 15 Dec 2007 10:25:35 -0800 (PST)
