Pietenpol-List: stripping varnish
Posted: Sun Jan 13, 2008 2:19 pm
Original Posted By: "Andrew M Eldredge"
Posted: Sun Jan 13, 2008 4:05 pm
Jeff; in the repair and rebuild of sections of 41CC I had occasion to remove varnish in many places but none of them very extensively. My experience is therefore limited and I'm certainly no woodworker, but all I did was sand away the varnish before epoxying and I believe all of the new joints came out nice and tight.Varnish is quite thin though, so I'm sure it goes way deeper than sanding will remove. Just not sure how detrimental that residue is to an epoxy going on over it.Oscar ZunigaSan Antonio, TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________
Re: Pietenpol-List: stripping varnish
Posted: Sun Jan 13, 2008 6:01 pm
Posted: Sun Jan 13, 2008 6:03 pm
Jeff,A heat gun is a must when removing varnish. With a little practice you will learn to heat the varnish just to the point it becomes "gummy" and it will scrape right off with a scraper. Once the varnish is removed you can use the heat gun to preheat your engine in cold weather.Gene ________________________________________________________________________________Date: Sun, 13 Jan 2008 21:17:53 -0500
Re: Pietenpol-List: Re: Forming Plexiglass and Lexan
Posted: Sun Jan 13, 2008 6:47 pm
Jim,I suggest you Google "Fly Baby Windshields". Very interesting.Gene________________________________________________________________________________
