Re: Pietenpol-List: You didn't say how many VW's...
Posted: Thu Apr 10, 2008 6:28 pm
About 40 years ago, a guy by the name of Lacey in Tulsa did use a pair of 40hp VW engines to repower his M-10 homebuilt (it did have a C-90) -- the swept area of (2) 4 1/2 ft dia. VW props is a bit more than that of a 6ft Piet prop. What Would Bernard have Done?? Who knows!Cheers!Mike C.Pretty Prairie, KS________________________________________________________________________________
Re: Pietenpol-List: Passenger seatbelt attach points
Posted: Thu Apr 10, 2008 11:00 pm
Original Posted By: "Tim Willis"
On NX18235 the passenger lap belt is anchored to the ash cross piece at the bottom of the seatback. The shoulder harness is anchored to a lug that is welded to the right rear cabane strut.Greg Cardinal----- Original Message -----
Re: Pietenpol-List: Engine choices
Posted: Fri Apr 11, 2008 4:56 am
Original Posted By: _Milt Atkinson_ (mailto:miltatkinson(at)verizon.net)
Subject: Re: Pietenpol-List: Engine choicesLog onto the Dawn Patrol web site. They (8?) are all flying WWI replicas with VWs. Mostly make about 60 HP but can be built up to 100HP. I built a Half vw from Great Plains and it really roars. All new parts!In a message dated 4/10/2008 12:50:37 P.M. Central Daylight Time, silvius(at)gwi.net writes:I know that the general advice is against it, however I know VW conversions with the redrive fly on the CH701 and CH601. I am also aware of a Pipper Cub in Brazil that has flown successfully on a VW.it is experimental aviation after all.Michael----- Original Message -----
RE: Pietenpol-List: Passenger seatbelt attach points
Posted: Fri Apr 11, 2008 6:48 am
