Posted: Thu May 01, 2008 12:24 am
er23(at)gmail.com>> > >> > > A couple of questions about the gussets on the wing ribs....> > >> > > I have the full size rib print, although I didn't use it to layout > > the jig. I'm cutting pieces of thin cardboard to match the gussets as > > shown on the full size print, and then I'll use those patterns for > > cutting gussets from the sheet of 1.5mm birch ply we bought from AS&S. > > Are there any discrepancies in the gussets as shown on the full size > > print?> > >> > > The top gusset on the rear spar upright is a rather odd shape, > > insofar as how it extends down the 45 degree rib member. I wonder if > > it would be better to just extend it out to be a full square so it > > might be a little stronger. Of course, then I look at it and think > > that if it needed to be that way then it would have been drawn that > > way.
> > >> > > Otherwise I think I've found most of the posts on the other things > > to be careful of: scuffing the birch before gluing, cut the gussets > > out so you have vertical grain orientation. I was thinking of using > > weights on the gussets and leaving the rib in the jig overnight to > > dry. Stapling (and removing the staples later) sounded good as well, > > speeding up the process, but I worry about having the gusset shift > > when the staple is driven in. Is this a concern?> > >> > > Thanks for the help,> > >> > > Ryan> > >> > >> > >> > >> > > Read this topic online here:> > >> > > http://forums.matronics.com/viewtopic.p ... 454#180454> > >> > >> > >> > >> > > ====> > >> > >> > >> >> >> > ------------------------------------------------------------------------> > Email Australia. Be part of history. Take part in Australia's first > > e-mail archive w=======================> > >_________________________________________________________________It's simple! Sell your car for just $30 at CarPoint.com.aue%2Ecom%2Fcgi%2Dbin%2Fa%2Fci%5F450304%2Fet%5F2%2Fcg%5F801459%2Fpi%5F1004813%2Fai%5F859641&_t=762955845&_r=tig_OCT07&_m=EXT________________________________________________________________________________Date: Thu, 1 May 2008 10:40:34 -0500 (GMT-05:00)
