RE: Pietenpol-List: Bare wood wing storage
Posted: Sun Mar 15, 2009 10:45 pm
My first wing, after varnish was hung on my basement ceiling.- The wood for that wing had been in the heated basement for two years.- The other day when getting ready to store my second wing I noticed quite a few loose bolts on the first one.- I had no idea the wood dried out and shrunk that much after storing in the controlled atmosphere.Jackwww.textors.com-________________________________________________________________________________Date: Tue, 17 Mar 2009 06:09:13 -0700 (PDT)
Posted: Mon Mar 16, 2009 2:49 am
I hung my newly finished right wing up in the gargage flat against the wall. It is just a bare wood wing. (no cover, no cables) The garrage is attached to the house but no heat/cooling. Curious if this is an all right environment to-store the wing as I build the left one and fuselage? Our garage is-only used for our cars and is kept quite clean. (no lawn equip., toys, tools, etc.)=0A=0A=0A ________________________________________________________________________________Subject: RE: Pietenpol-List: Bare wood wing storageDate: Mon, 16 Mar 2009 14:45:51 -0500
1 AM GMT -08:00 US/Canada Pacific=0A Re: Pietenpol-List: Birthday f
Posted: Mon Mar 16, 2009 12:35 pm
> Re: Pietenpol-List: Birthday flying
Posted: Mon Mar 16, 2009 2:20 pm
Re: Pietenpol-List: Airport is in trouble!!
Posted: Mon Mar 16, 2009 3:59 pm
Subject: Re: Pietenpol-List: Airport is in trouble!!Amen to that, if they surveyed across your property without an easement or your permission, feel free to remove the ILLEGAL survey stakes after you take pictures then contact law enforcement to pursue trespassing charges.Joe MotisWW CorvairDealt with this crap at my airpark for a water line, they tried to push me into a easement through a certified letter including playing stupid with me and when asked for compensation you should have heard him sputter. .This was 5 years ago and still no water line.no archiveIn a message dated 3/16/2009 6:40:30 A.M. Pacific Daylight Time, jb.spiegel(at)us.schneider-electric.com writes:Shad, Having read through the replies, you are on the right track, A couple of things I thought of. I don't know how Ohio is, but in the state of Iowa, any utility must have an easement both temporary for construction and permanent for maintenance, if the Owner of the airfield owns the entire strip then they should have to obtain his/her signature for the easement, if that person refuses to sign, thenthey will have to pursue eminent domain, which is not a quick process. Also contact the County Engineer to find out when the project was approved by the County board of Supervisors. If they are doing preliminary survey work, then they should contact home owners prior to entering their property, unless they have an easment, or a court order, otherwise it's trespassing. Also dont' be affarid to question them when they are on the airfield or your property, Jake (
http://www.matronics.com/Navigator?Pietenpol-List) (
http://www.matronics.com/contribution) **************Feeling the pinch at the grocery store? Make dinner for $10 or less. (
http://food.aol.com/frugal-feasts?ncid= ... od00000001)________________________________________________________________________________Date: Tue, 17 Mar 2009 06:01:59 -0700 (PDT)
