Pietenpol-List: Aileron response & stick movement
Posted: Sat May 02, 2009 10:38 pm
Has anyone shortened the aileron horns from stock length in order to get a faster roll response with smaller stick inputs? After flying my plane 300+ hours, there have been times where I wished I had more aileron. Typically in gusty, high wind conditions during turns. Especially when turning into the wind (like base to final), I've experienced gusts that tend to pull the low wing further down...not a comfortable situation when you are already low. Max aileron input in the opposite direction gives a response that is delayed and much slower than I would like. I'm running out of room for the stick, as it hits my leg. There is more aileron deflection left before I hit the stop, but in my typical flying position my leg is in the way (I'm about 6'0", BTW, with a stock Piet cockpit). If I shift to one side and lift my leg I can get more aileron deflection, so I'm not talking about increasing total deflection, just increasing the response rate.It seems that shortening the aileron horns 20% to 30% would give me more deflection for the same stick movement. What are the potential downsides that I'm not considering? Has anyone done this? I'm interested in any thoughts or opinions on the subject.Thanks,Steve RuseNorman, OK________________________________________________________________________________
