RE: Pietenpol-List: radio install
Posted: Fri Jun 05, 2009 12:19 pm
Jack, I will see you in brodhead next month. Piet is not ready yet but close.I lost your paper on the transponder install. I am ready for it now. Do I needan encoder too? By the way, How much does a 0-200 weigh with starter and alternator.My corvair is at 240 lbs. My last weight check was 751 lbs. It's probablya little higher since I had to rebuild the center section gas tank whichhold 19 gallons(aluminium this time). Cheers, Gardiner Mason PS You would'nthave to fly over all those mountainous trees if you flew down this way and thento brodhead. I would like for you to see my project and I know the big pietbuilders would like to see you too.-------------- Original message ----------------------
