Pietenpol-List: Turnbuckle safety
Posted: Sat Jun 20, 2009 5:12 pm
Can anyone suggest a safety wire method for this turnbuckle? Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.)________________________________________________________________________________
Pietenpol-List: Re: Turnbuckle safety
Posted: Sat Jun 20, 2009 6:19 pm
what, you questioning about the end in the photo?? just run the wire around the end and single wrap it. It does not have to go through the hole with the pin to do it's job. Or am I missing the question??Gene________________________________________________________________________________Subject: Pietenpol-List: Re: Turnbuckle safety
Posted: Sat Jun 20, 2009 6:40 pm
Original Posted By: "Mandy & Michael Green"
I don't know whether you have room or it would be permissible,but maybe drill ahole in the tab to run the wires through on that end and twist off-it obviouslycan't turn the eye on that end.I would think if you cross wrap the two wiresfrom the middle hole to the tab and go through it and twist together it shouldwork? RaymondRead this topic online here:http://forums.matronics.com/viewtopic.p ... __________
Re: Pietenpol-List: Turnbuckle safety
Posted: Sat Jun 20, 2009 7:01 pm
Gary,You could use turnbarrel clips. See picture.Mike GreenAustralia ----- Original Message -----
RE: Pietenpol-List: Re: Turnbuckle safety
Posted: Sat Jun 20, 2009 7:12 pm
Thanks, Gene...Thanks, Raymond. I went out on the back porch, had a glass of ice water andcommuned with nature for a few minutes, and came up with the exactresolution you describe. I can now use the double wrap method.For any who may not have followed, I probably purchased the wrong end. Afterthe pin went thru (which fits tightly), I had no place to run the safetywire thru. As Raymond suggested, I drilled a small hole, big enough for thesafety wire, on the exposed part of the tab. Life is good.....Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.)-----Original Message-----
RE: Pietenpol-List: Turnbuckle safety
Posted: Sat Jun 20, 2009 7:16 pm
Thanks, Mike! Unfortunately, I did not buy the clip type of barrel (not sureIf the Pietenpol Police would allow it). ;-)I'm too cheap to replace them, too. As a matter of fact, I seriouslyconsidered some of the old-time alternatives to turnbuckles! Those thingsare WAY TOO EXPENSIVE!Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.) _____
Posted: Sat Jun 20, 2009 7:18 pm
Gene,Re-reading your reply.and I had considered that, too. You were not missinganything. Anyway, I ended up drilling a hole..Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.) _____
Posted: Sat Jun 20, 2009 7:43 pm
I thought I should include a picture showing my fix...sorry for thefuzziness, but the hole is the shiny part, just at the end of the turnbuckleend.I know, I know...if the Gestapo sees this I could lose my A&P cert. This fixwould not be a consideration if these were primary control cables.GaryThanks, Gene...Thanks, Raymond. I went out on the back porch, had a glass of ice water andcommuned with nature for a few minutes, and came up with the exactresolution you describe. I can now use the double wrap method.For any who may not have followed, I probably purchased the wrong end. Afterthe pin went thru (which fits tightly), I had no place to run the safetywire thru. As Raymond suggested, I drilled a small hole, big enough for thesafety wire, on the exposed part of the tab. Life is good.....Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.)-----Original Message-----
Re: Pietenpol-List: Re: Turnbuckle safety
Posted: Sun Jun 21, 2009 3:19 pm
Gary, you didn't drill through the turnbuckle fitting did you!!!!!!!!!????????????Gene ----- Original Message -----
Posted: Sun Jun 21, 2009 6:59 pm
Yes. I know that renders it un-usable in the world of certified aircraft,but I am really not concerned in this use. As I said, I would never do thison primary controls. I would be willing to bet that there are flying Pietsout there without AN hardware.Do you, or anyone on this list, have experience that would dictate other?Gary BootheCool, Ca.PietenpolWW Corvair ConversionTail done, Fuselage on gear(13 ribs down.) _____
Pietenpol-List: Re: Can I use 12 Gage spokes in my 17
Posted: Sun Jun 21, 2009 10:12 pm
Original Posted By: "rameses32"
I am nominating William Wynne=2C "The Corvair Authority"=2C for this award based on his tireless contributions towards experimental aviation and affordable engine conversions for our airplanes. William is the perfect example of what it means to be an outstanding individual in light aircraft development. I encourage you to place your own e-vote by emailing lpburke5@comcast.net and voting for William.Thanks. Here's the text of the invitation:>Dear Aviation Enthusiast (via editor(at)contactmagazine.com):> > Some time ago in early Jun we asked for your nomination of some> individual in the field of light aviation that you think deserving of> the prestigious "LAMA Award for Outstanding Individual."> > We value your input very much=2C as the winner is the one who receives> the most nominations=2C and we want to make sure that we are getting a> representative cross-section of the USA and International light> aviation community.> > Each year at EAA AirVenture=2C the Light Aircraft Manufacturers> Association (LAMA) awards some individual this award.>The award is presented at show central the first day of AirVenture.> This will be our 18th year of presenting this award.> > Therefore=2C we ask you to please nominate someone you think deserving> of the award.> Previous winners of the award=2C no longer eligible=2C appear below.> > Thank you very much!> > Larry Burke=2C Chair Emeritus> Light Aircraft Manufacturers Association> > Here are our past winners:> > Dick VanGrunsven> Randy Schlitter> Lance Neibauer> Phil Reed> Homer Kolb> Dennis Soder> Tom Peghiny> Bob Gavinsky> Darryl Murphy> Chris Heintz> Chuck Slusarczyk> Mike Loehle> Phil Lockwood> Earl Lawrence> Dan Johnson> Eric Tucker> Matthias Betsch> Oscar ZunigaAir Camper NX41CCSan Antonio=2C TXmailto: taildrags(at)hotmail.comwebsite at http://www.flysquirrel.net________________________________________________________________________________Subject: Pietenpol-List: Re: Can I use 12 Gage spokes in my 17
