Pietenpol-List: found on craigslist
Posted: Sun Jul 05, 2009 9:13 pm
Original Posted By: ken anderson
Subject: Pietenpol-List: found on craigslist
Posted: Sun Jul 05, 2009 9:41 pm
Original Posted By: Ameet Savant
Re: Pietenpol-List: found on craigslist
Posted: Mon Jul 06, 2009 3:22 pm
Posted: Mon Jul 06, 2009 3:34 pm
Pietenpol-List: Re: found on craigslist
Posted: Mon Jul 06, 2009 3:55 pm
Having rebuilt more than a few Model A and Model T engines, I can tell you thatthere are virtually no interchangeable parts between the two with the exceptionof a few bolts. The '28 engine, if original, has a forged steel crankshaftwhere the '29-'31's had cast cranks. The forged crank is much stronger and lighteras well, since it's not as massive; a good choice for a Piet. However whoknows if a rebuilt engine still has the original crank; most likely not. I wouldthink it wise to gather the parts and rebuild the engine yourself farmingout the machine work as needed. There is about $1,000. in bearing and machinework in the "A". Parts; I'm not sure about current prices on these, but that muchmore should buy whats needed along with an aluminum head. A re-buildable block,crank, rods and cam shouldn't be more than $500. if that much. So you nowhave the $2,500. in an engine that you know what's inside.Read this topic online here:
