Pietenpol-List: bird strike
Posted: Wed Sep 16, 2009 11:44 am
Original Posted By: airlion
Subject: Pietenpol-List: bird strikeI wonder how it made it thru the prop arc before hitting the upper part of the cabane ?________________________________________________________________________________Date: Wed, 16 Sep 2009 10:21:45 -0700 (PDT)
Posted: Wed Sep 16, 2009 12:31 pm
Original Posted By: H RULE
RE: Pietenpol-List: bird strike
Posted: Wed Sep 16, 2009 2:12 pm
I once had a bird hit me in a flexwing. Put a hole in the fabric andleft feathers on the carbs then went into the prop ( a pusher) I saw itflying up toward me from a thermal created by an asphalt plant rightbelow crosswind in the pattern at BCV. Scared the peewaden out of mebecause it made a loud pop when it hit the wing. Birds are a danger we need to heed.Rob Stapleton, PhotojournalistAnchorage, AK(907) 230-9425KL2ANSkype:rob.stapleton.jr-----Original Message-----
Re: Pietenpol-List: bird strike
Posted: Mon Nov 28, 2011 9:54 am
Subject: Re: Pietenpol-List: bird strikeIf you and the bird were on the same heading would you have to dive in order to strike the bird? Chrissi & Randi_www.CozyGirrrl.com_ (http://www.cozygirrrl.com/) CG Products, Custom Aircraft HardwareChairwomen, Sun-N-Fun Engine WorkshopIn a message dated 11/28/2011 9:47:38 A.M. Central Standard Time, timwillis01(at)gmail.com writes:--> Pietenpol-List message posted by: Timothy Willis Lowell,Glad you are OK and the Piet only lightly damaged.That would increase the pucker factor. Imagining a truly head-onstrike, nose-to-beak is terrible.Sounds like you did all the right things.regards,Tim in central TXdo not archive________________________________________________________________________________Date: Mon, 28 Nov 2011 08:41:06 -0800 (PST)
Pietenpol-List: Re: bird strike
Posted: Mon Nov 28, 2011 7:49 pm
My brother was flying under a flock of birds and when he got directly under theflock for some reason the birds dove down, their instincts were to get away fromthe predators, he got hit buy 3 birds from the top. Lesson one:Stay away fromflying things.Pieti LowellRead this topic online here:http://forums.matronics.com/viewtopic.p ... ___Subject: Pietenpol-List: Re: bird strike
