> Pietenpol-List: throttle setup
Posted: Sun Oct 04, 2009 4:15 am
et>Jorge & Oscar, Corky's second project (now mine) is as Oscar described-- the two throttles are connected by small diameter steel push-pull tubes, with a Bowden cable from the front pit to the carb.- The handles are on top.- I plan for a left glove (leather, no lace, Michael Jackson) to keep 100 mph June bugs and chilling air off my knuckles.- Usually- chilling air is not a major factor in TX, or Oscar would have fixed that.- Tim in central TX -----Original Message----->From: Oscar Zuniga >Sent: Oct 4, 2009 11:01 AM>To: Pietenpol List >Subject: Pietenpol-List: throttle setup>>>Jorge; I think the throttle that is shown in the>plans is about as simple as you can get.- One thing>that would be an improvement is to link the front>and rear throttle levers with a rod or tube, then>carry a Bowden cable forward to the carb from the>front throttle.- I've seen pictures of that setup>on more than one Piet but I don't remember whose>airplane had it.- The last ones I saw were of a>really nice, clean, simple cockpit with beautifully>varnished plywood cockpit; I'm no wood expert but>it looked like birch ply (blonde color), dark hardwood>knobs on the throttles.> >41CC has the pilot's throttle up near the cockpit>coaming with the pivot at the bottom; upside-down>from what the plans show.- I like that setup since>it gives more room down in the cockpit but when the>weather is cold, it puts your hand almost out in>the wind.- I can post a photo of the throttle if you>are interested.- And the front throttle is just a>knob attached to the inner wire of the Bowden cable>with bug nuts to secure it.> >PS: "Cold", as defined in Texas, is anything>below about 80F.>>Oscar Zuniga>Air Camper NX41CC>San Antonio, TX>mailto: taildrags(at)hotmail.com>website at http://www.flysquirrel.net --- -------- ------ --- - >>le, List Admin.=0A=0A=0A ________________________________________________________________________________Date: Sun, 4 Oct 2009 14:57:44 -0700 (PDT)
